Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Why is my ABS light on in my 1999 vw passat - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • 2,418 Answers
ABS systems are just, two wheel sensors and the main ABS ecu, if you have a light "on" the ecu (Electronic Control Unit) is working, but you have a Fault in the system. Check the fulid in the reservoir, thats the easy one. You will have to check the wheel sensors, you have one on each front wheel. Check the wiring to the sensors, ck the front brake pads.  You can use a volt/ohm meter to check the wheel sensors, jack up the wheel and using the volts a/c setting, conect to the two wires and spin the wheel, you should get a small voltage reading while the wheel is spining say (1.23 Vac) not much but you can see then you have a good wheel sensor. Check that OR go to a local parts store and see if they can read the code.
Posted on Sep 24, 2009
Testimonial: "Thank you very much"
Asr light stays on vw passat 99 2.8 what can i do to turn it oof?
CHECK FOR CORRECT CODING OF THE MODULE AND EXECUTE THE BASIC SETTINGS OF THE ABS ECU........TEST DRIVE AND THE ASR WILL GO OFF!!!LET ME KNOW...
Feb 17, 2015 | 1999 Volkswagen Passat
I GET OIL LIGHT ABS AND BRAKES THE CAR RUNS FINE LOOKS LIKE COMPUTERB 1999 VW PASSAT WHAT DO YOU THINK
Have the alternator checked,if the voltage is too low this will happen.Please rate,if this was helpful at all,thank you.
Jun 21, 2010 | 1999 Volkswagen Passat
Same here! ABS & oil lights come on, tachometer stops & no AC
try having your battery and alternator tested,it could be a volt drop.also check the main earth points to the body.good luck.
Sep 30, 2009 | 1999 Volkswagen Passat
1999 VW Pasaat Tach Inop, Oil Lite & ABS lite on
Sounds like you have a lose wire or connection in your dash cluster
Aug 27, 2009 | 1999 Volkswagen Passat
Fit new indicator stalk to VW passat esp , abs light on now
the stalk should have no interference with the abs or esp set up what i would look at doing is checking your abs sensors they can go all of a flash...goodluck
Jun 19, 2009 | 2004 Volkswagen Passat
Lights on scanner will not read the dtc 99 vw passat
you need a laptop and vag-com program to properly get codes from vws. other scan tools my just even throw you a totally wrong code#
Apr 24, 2009 | 1999 Volkswagen Passat
2002 vw passat wagon abs light on
this takes a dealer only scan tool to diagnose.
Mar 23, 2009 | 2002 Volkswagen Passat
I have a 1999 VW passat wagon that have the abs, brake and check
you might want to look at the wireing under the floor mat on the driver side. there is a well that water collects in and eats throught the wires. i had this happen to me and found 6 or 7 wires that rotted tru. i fixed the wirs and then used rtv(silacon calk) to cote all the wires to protect them frome more water damage. hope this helps.
Feb 28, 2009 | 1999 Volkswagen Passat
ABS/BRAKE warning lights always on in 2000 VW Passat
dont guess !! get it plugged into a scanner and see what the code is
Feb 18, 2009 | 1999 Volkswagen Passat
Oil light and brake lights blinks on and off and abs light is on
Just a idea. If the car is running at idle and the oil light blinks , it usually from low oil pressure. At a idle your seeing the light respond to the revolutions of the engine. ! thing to try is to replace the oil pressure switch on the engine block. And #2, Most causes in a VW is that the vehicle overheated at one time and weekend the oil pump,or massive amount of miles.
Jan 14, 2009 | 1999 Volkswagen Passat
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
161 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
