Question about HP Compaq Presario V5000Z Notebook
LAPTOP KEYBOARD My keyboard hax one key the q key that doesn't work properly. The key pushes hard and seems like the spring has gone out of it. It works if you push on it hard enough on it but its not free and springy like the rest of the keys. Can I fix this or can it be fixed? Thank you.
    Problem Solver:
  • 14 Answers
Sometimes food or other things get stuck under the key. Turn the laptop upside down and shake it out or use can o air. Otherwise keyboards can be replaced for a minimual cost.
Posted on Apr 22, 2008
    Sergeant:
    Champion:
  • 317 Answers
Newer laptops don't have 'springs' they use rubber or silicone pads for support.
You could try prying the key open (with a thin clip or something) being careful not to damage it or the keys surrounding it.
Check for any debris or lint. Blow on it or just turn and shake it, you might find a staple or something.
Posted on Dec 16, 2007
Fix 3 beeps on a laptop and can not start up
3 beeps keyboard
desktop or laptop ?
Keyboard is not connected properly. Stuck key Bad keyboard Bad PS/2 or AT port Solution Keyboard is not connected properly Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. b>
Jan 19, 2013 | Dell Dimension 2400 PC Desktop
Keyboard doesn't work
To determine if the motherboard is faulty, connect an USB keyboard to your laptop an see if the keyboard works properly. If so then the laptop keyboard may only need the keyboard connector unplugged and then plugged back onto the motherboard.
Nov 29, 2012 | Gateway NE56R10u Laptop
Does your laptop work when you plug in a USB keyboard? When you startup the machine, do the keys respond (depending on your laptop, push the key to get into the system BIOS). If it allows you to get into the system BIOS, then it maybe a software issue.
Oct 21, 2012 | Sylvania G-Netbook
The fn keys dont work in my asus except for the fn+f7 one. when i press fn+f2 the led light goes on and off but it doesn't seem to work??? what should i do??
Hook a external keyboard to the laptop, if all functions checkout. The keyboard in the laptop will need to be replaced..
Mar 30, 2012 | ASUS Computers & Internet
Compaq CQ60 some keys not working
The keyboard maybe faulty.
Connect an external keyboard to youe laptop and if all the key work on this keyboard then most like the laptop keyboard is faulty.
If this external keyboard also malfunctions then the keyboard controller chip on the laptop motherboard is faulty and it would not be worth repairing as this is an old model laptop.
Mar 04, 2012 | Compaq Presario CQ60-212US Notebook
Hi, i have a toshiba x205-s9800. my two year old seems to have accidently pressed some keys and disabled the keyboard...please help...
You could have deleted the keyboard in the device manager. If so, rebooting your computer and it will find it.
Are all the keys not working or just some? Take a look at this hint and see if it fits.
http://www1.fixya.com/support/r5966678-letter_keys_now_produce_numbers
I do this for fun & feedback not $$$
Oct 02, 2011 | Toshiba Satellite X205-S9349 Notebook
ACER ASPIRE laptop PgUbp key came off.
Unless I'm missing something, just put the key back where it belongs. Push down hard, and it'll snap back into its place. If this doesn't work, check the underside of the key. If you see broken plastic, you'll probably have to find a new key. Acer laptops seem to have a problem with keys coming out and breaking (just look at the number of times this question has been asked!)
hope this helps
Apr 06, 2011 | Acer 90.46907.001 Keyboard
Some keys on my laptop`s keyboard doesn`t work such as g, h, backspace, fn and the windows button, what can I do?
Hi, if you spilled liquid on the keyboard then it probably needs to be replaced,
Try this... you can remove the keyboard by removing certain screws from the bottom of the laptop, then you open the laptop like if you are using it look to for sliders around the keyboard edges or if it just snaps in place, use thin flat screw driver to carefully remove the keyboard but do not pull far.. it should still be attached with a wide flat cable to the main board... now lets try to remove the cable completely and re-attach it ( when removing the cable use your small flat screw driver to pull the plastic connector snaps from the sides of the connector to loosen the cable and be careful not to break the connector, when attaching back put the cable in first and hold it while you push the connector plastic back in place)... try the computer to see if the problem is gone, if not then order another keyboard and replace it. best of luck
Jan 26, 2011 | HP Laptop Keyboard for HP Pavilion DV6000...
Gateway model 7422gx keyboard issue
a computer store of sorts would have the piece for you. for now, just use a different keyboard if you can. when my key came off, i was able to snap it back on. :)
Oct 12, 2009 | Gateway 2520915 Keyboard
Keyboard problem. Key 3, @, #, y, n can't use
you may have shorted your keyboard (spillage??)
if your laptop is outside warranty you can check the connection to the keyboard, by removing the top bezel, undoing the keyboard retaining screws and then check that the ribbon cable for your keyboard is seated properly, If reseating this cable does not work the you can always order a replacement for your keyboard, you can find the part number for the keyboard you have, it should be printed on a tag on the reverse of the keyboard.
May 24, 2009 | Acer Aspire 3680 Laptop
HP Compaq Presario V5000Z Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
