Question about Garmin nuvi 255W GPS Receiver
Loose satellites, kept loosing them for about three hours, in areas that had mountains
  • 35 Answers
Anytime you are in either a garage,between tall buildings or as you discovered mountains it is very hard to get to a Satellite.Try stopping and standing outside for a few minutes to see if you can pick up a Satillite,good luck.
Posted on Sep 25, 2009
Power windows mercury mountaineer
wiring harness should be under the left side. covers on the floor area , next to the seats....... in the post area, that your front door locks into , and the hinge area on the rear door..... wiring is wrapped in main harness....
Apr 12, 2014 | 2000 Mercury Mountaineer
Toshiba model#50HDX82
Have you checked for Loose Connection(s) or even sparking at the Socket?
Recheck for loose connection from the adapter to Laptop cable.
Mar 25, 2012 | Toshiba Satellite M45-S331 Notebook
How to fix the door handle and lock on a 1999 mercury mountaineer
Not sure which handle you are talking about but if its the inside handle it may just have come loose, you will need to check the bolt or it may have broken at the hinge , same with the outside handle if its loose it may just need tightening or it may have also broke at hinge area. you will need to remove the door panel to get a better look at things.
Dec 06, 2011 | Cars & Trucks
Rino 530 keeps loosing signal was hunting in Canada using rino while walking . keeps saying no satalite
The GPS needs a clear view of the sky and at least 3 or more satellites to get a fix on your position. If you are under a heavy canopy of tree cover / brush, it can affect accuracy and even the GPS's ability to get a fix at all. Also, if you are in a mountainous region, the geometry of your location and the location of the satellites over the equator could be obstructed, resulting in the lost satellite messages. You must have an unobstructed view of the southern sky to get a fix.
If you are able to get a fix in an open area, the GPS is able to do its job, but the location you're trying to use it in is offers too much interference to capture satellite signals.
Making sure you've got the latest firmware from Garmin can solve a lot of troubles, too. If you still believe that your GPS isn't working the way it should, contact Garmin Support.
I hope this helps - and good luck. Please rate my reply - thank you.
Feb 23, 2011 | Garmin Rino 530 GPS Receiver
Keep loosing satellites
I f you are in an area where there are tall buildings,
mountains or even in your garage it has difficulty picking up a Satellite,only thing I can reccomend is to restart the GPS outside,wait a few minutes and it should pick up a Satillite.Good luck.
Sep 24, 2009 | Garmin nuvi 255W GPS Receiver
I have a 99 Mountaineer. Recently replaced the
If it is a continuous thump (ie thump, thump, thump) that changes in speed with the speed of the vehicle it is likely related to a tire problem.
If it happens when you hit a bump or immediately afterwards it is likely due to something loose or worn out in the suspension.
If it happens somewhat randomly and doesn't seem affected by bumps it may be a loose piece of trim, or something loose under the car getting knocked around by the winds.
Jun 13, 2009 | 2002 Mercury Mountaineer
Toshiba Satellite L300 kept turning off
Sounds like a device driver conflick before you try to restore reboot the laptop and at startup press F8 at the menu click onsafe with networking so that if you need to download drivers yo can " Right click on my computer clik on manage look in event viewer and see when errors started to happen if the was a software update at the time of the error uninstall it and reboot the computer. if not you may have to restore the system to and earlyier date and loose data Good luck
Mar 25, 2009 | Computers & Internet
Cobra GPS 500
Regardless of which GPS unit you use, finding sufficient satellites can be difficult if you are working in an area with trees/mountains/hills or other obstacles. Here are some suggestions to locking onto satellites:
1.) Mission Planning. If you think you're going to be working in a tricky area, but sure to check mission planning. This software allows you to input a location and obstacles, and gives you the times when satellites will be best.
2.) Wait. It takes the GPS units varying amounts of time to "find" satellites, but if satellites are visible, the unit should lock on within 5 minutes.
3.) Move. If possible, move into an area that has a clearer view of the sky.
4.) Face south. This is especially important if you are using the GeoXT. Turn the GPS antenna so that it is facing the southern sky. The majority of satellites have their orbit so that they appear in our southern sky. There are also satellites in the east and west, and almost no satellites to the north.
5.) Rotate around. If facing south doesn't work, slowly rotate the GPS around 360 degrees.
Oct 22, 2008 | Cobra GPS500 GPS Receiver
IS THERE ANYTHING SPECIAL I HAVE TO DO WHEN FIRST USING THE GARMIN 350....I TURNED IT ON AND IT WONT PICK UP THE SATELITTE
Hello gdepari,
Take the GPS outside into an area with a clear view of the sky and turn it on. The unit may take up to five minutes to lock onto satellites and determine your current location. The GPS needs to receive data from at least three satellites. If you are operating indoors, in a vehicle, in a city with tall buildings, or in an area with tall hills or mountains, your view of the sky may be blocked. This can prevent the GPS from locking on or can cause it to take additional time getting a satellite lock.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 22, 2008 | GPS
Garmin nuvi 255W GPS Receiver Logo
64 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
