Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
When i pull to start my trimmer the gas is comming through the exhaust and it won't start what could be the problem?
  • 85 Answers
Its flooded, do not choke it, change the plug& hold the throttle open & try to start
Posted on Sep 24, 2009
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
Spool won't turn when trimmer is turned on?
Has the engine siezed or does it still pull over.? If it still pulls over, its probably a recoil starter issue.
Apr 09, 2012 | Husqvarna 28cc Gas Line Trimmer
Hedge trimmer , mod.040090D 40350. Won,t start.. I pulled the plug, grounded the plug body, a spark should be seen at the plug gap., but instead a spark is seen from the plug body to ground, what would...
You will see a spark jump from the plug body to ground if it isn't tightly grounded to the engine. However a spark should also jump the gap in the plug at the same time. It can be difficult to check a plug this way because it tends to bounce around the place when pull starting the engine. You could try getting a bit of wire and clipping on end to the exhaust or fin on the engine with a crocodile clip, clothes peg or vice grips. The other end of the wire could be wrapped around the threads of the plug and held with a clip.
Fore more tips on starting a hedge trimmer see:
http://fixofile.host56.com/tips2.html#tip2
Nov 24, 2011 | Craftsman 22" Gas Hedge Trimmer
Won't start. String pull will not go more than a few inches. Engine seized?
Try the clutch. I just fixed this problem.One of the clutch springs ate it's way though the red housing where the spring for the pull start is at. When the housing came apart the engine seized and I couldn't move the pull start. For the schematic on the engine here is the web address http://www.searspartsdirect.com. Hope this helps.
Aug 20, 2011 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
I have a Husq. 326 L trimmer; my pull cord seems to tug and becomes almost unpullable and it wont start; I have a new spark plug-what could be causing this?
Pull your plug back out and see if your cylinder is full of fuel, if this is the case your needle/seat is leaking fuel into cylinder causing hydrolocking (gas won't compress) good luck
May 02, 2011 | Husqvarna 28cc Gas Line Trimmer
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Gas Trimmer will not stay started
Have a similiar problem with a John Deere trimme (T 105C) and was told by the dealer that it is a carburator problem and would need to be replaced. Cost of the part is $105.00 plus labor. Not worth it to pay to buy the part & have it repaired. Good luck.
Sep 29, 2008 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
137 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
