Question about Mitsubishi WD-62528 62 in. LCD Television
TV does not come on
I have a Mitsubishi WD-62528 TV and have recently had an issue of the TV not coming on. When powering up the TV the lamp light starts flashing green and the status light flashes yellow. After about a minute the lamp light goes out but the status light remains flashing. I have already replaced the expensive lamp in it to no resolve. You guys have any ideas? A friend of mine says that you guys are the best...not to add any pressure or anything.
  • Anonymous Mar 26, 2008
    tv mitsubishi wd - 62528 will not turn on
  • anyautoparts Sep 18, 2008
    Yes i have the same problem status light keeps flashing and tv will not power up, Dose anyone have any idea what the problem is. Please let us know.
  • 33 Answers
Similar problem with my Sony. Unplug for 36 hours from the wall and it fixed my problem
Posted on Aug 31, 2009
Where is the DM Module on a Mitsubishi WD-62528?
A few pieces of advice--the boards are sandwiched in the main signal chassis and not easy to get at.
If you have replaced those 4 in the actual power supply they do for some models sell the entire signal chassis (has almost everything except the optical light engine) for about 250 exchange.
Let me know what issues you have and I may have suggestions--this model has one very odd issue that is simple---picture gets so dark it is hard to see--not the lamp but easy to fix.
May 26, 2012 | Mitsubishi WD-62528 62" LCD HDTV
I have a 62inch Mitsubishi wd-62528 when I plug it in the timer power light blinks green rapidly, it turns on once and not for long then shuts off with no light
There should be a system restore button on the front that you can use a ball point pen to press. If you hear a difference if operation (like the fans starting up) then you have reset the system. However if it does not come on and light up the screen then you are likely to have a bad lamp. The lamp has an access door either on the front or the back of the set and is usually on the back. Take the lamp out and inspect it for breakage inside the bulb. Also look very carefully at the root of the filament in the center for bubble like of the glass. If so it is bad and needs replacing. The best place I have found to get a lamp w/housing is
May 24, 2011 | Mitsubishi WD-62528 62" LCD HDTV
My mitsubishi wd-62528 has a constant rapid green blinking light on timer and wont go out. had lamp replaced and reset but wont even come on.
Thats a common problem most likley caused by failed capacitors on the DM and the power board. You can get the V26 Chassis DM / Power repair kit from which contains the capacitors and the CD with instructions for the repair.
Jul 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
The lamp went out and i change it but the lamp light is srill on and the tv come ongos to a blue screen about 3-5 min. then gos off
blue screen usually is signal related. it will shut down after a few minutes if it doesnt detect a signal.
Mar 16, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Replaced lamp about a month ago and now getting yellow/orange flashing light under lamp. What is the problem
Check in your operating menus on the TV as there is most likely a lamp timer reset that needs to be performed.
Oct 14, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Lamp lcd
Make sure lamp door is properly on, there is a sensor on the door.
Sep 19, 2009 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-62528 62 in. LCD Television Logo
246 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
