Question about Husqvarna 23 Hp 48" Deck Yard Tractor
The mower starts, the blades will engage, but when you release the brake/clutch (about 1 inch of the 6 inches of travel), the mower dies. The reverse switch position on the key does not have any effect. I can hear what sounds like a microswitch toggling at the same 1 inch of travel position. It seems like some safety system is shutting down the mower, but I can't find anything in the owner's manual about it.
  • farads44799 Sep 25, 2009
    Yes, I am sitting in the seat when the malfunction occurs. Doesn't seem to matter if the mower is engaged or not. Doesn't seem to matter if the key switch is in the Reverse Sensing position or in the normal position. The mower can only be towed (pushed/pulled) until this problem is fixed.
  • Husqvarna Master
  • 8,404 Answers
Here is a dumb question for you, are you sitting on the machine when you release the petal?
Most new machines have a 'operator presence' safety system on them. To run the machine, the operator must be in the operators regular position. I would guess you know this.
Can you release the brake and continue to run with the mower off???
Maybe your machine requires you to engage the drive and then the mower???
So, if the engine dies when you engage the drive system, the tractor thinks there is no one in the seat. Look for a switch malfunction under your seat.
Please let me what happens. Id like to solve this for you.
a
Posted on Sep 24, 2009
  • A Miller Sep 25, 2009
    Hi there and thanks for the clarification.
    With the understanding that this is a generic answer to your most serioius trouble, I say you have a safety switch failure. I would suspect that the seat is telling the mower there is no one sitting there even though, obviously, you are there.
    I suspect there is a switch on the seat, one on the pedal and one that works with the mower clutch. Seems to me the pedal switch is allowing you to start the machine but when you engage the mower traction dvice, the seat switch is saying NO GO. In other words, when you sit on the seat, the contacts on that switch are not making contact. You can try to short it out to prove or disprove this theory. I dont think you can damage the system by shorting this seat switch out - it should either be open (no one in the seat - no run) or closed (someone in the seat - ok to run). Dont short it to ground! - short it one wire to the other with a short piece of wire.
    If this is the trouble - repace the switch. Do not attampt to defeat its purpose.
    Let me know what you find out.
    I hope you find this information to be of some value.
    a
Where is the part located that shuts the mower off when you release the clutch
There is a safety switch for the brake clutch and if the seat safety switch is not activated by someone sitting on it, then the mower will die. So if you are sitting in the seat and the brake clutch is released and the seat safety is faulty then the engine dies, so the seat safety is where you should start looking.
Aug 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Replace switches & clutch. When brake is release everything dies. Ineed a wiring diagram.
There are a few safety switches on a riding mower. One is the brake clutch, which must be engaged to start mower if not in neutral for a manual transaxle. Another is a blade engaged safety that will not allow you to start it with the blades engaged and the other is the seat safety that prevents starting if the brake is not engaged.
If the seat safety switch is messed up and you release the brake it will kill the engine. I would start there.
I hope this helps get you going.
Aug 03, 2011 | Garden
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I have a Toro 1644 HXL mower.It starts fine but if you go to release brake/clutch or try to engage blades it dies immediately. Will start right back up? Safety switch?
u have a saftey interlock circuit issue, poss a bad seat switch or relay is causing it to die when the pedal is released.....good luck hope this helps oh and also might even be the blade switch itself.... get out the volt meter and go to work my friend!
Nov 19, 2009 | Garden
My Poulan 13.5 hp runs until cluch is released
remove the drive belts from the motor. if it runs ok check your pulleys. one of them might be siezed.if it still dies chk the safety switch on the gear selecter and deck engage lever.
Sep 25, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 42'' mower when clutch-brake is engaged and released...the level does not return to original position which prevents mower from running at selected speed. my manual does not provide diagram of...
Seems that your clutch needs adjustment, no biggie here. Get your needle nose pliers and a spare ¼ inch bolt or pin. A small Philips screwdriver will also work. The needle nose pliers are for removing the cotter pin and the screwdriver (or bolt) will hold the brake lever in place while you make the adjustment. Then, check under the right side of the deck (side where the grass discharges) right under the plastic mat where your foot rests and next to the tractor's frame you will see the brake lever with the long spring attached. Have a helper move the brake/clutch pedal so you have a better idea of what's going on down there. Then:
1. Remove the cotter pin, washer, and brake spring from the
adjustable nut
2. Disconnect the adjustable nut from the brake lever assembly
and the parking brake latch.
3. Align the hole in the brake lever with the hole in the frame. Hold
the brake lever in place with your 1/4 inch pin, bolt or the screwdriver.
4. Pull the clutch rod forward until tight. Turn the adjustable nut
until the nut will fit through the hole in the brake lever.
5. Assemble the adjustable nut to the parking brake latch,
brake lever and brake spring. Fasten with the washer and
cotter pin.
6. Remove the 1/4 inch (6 mm) pin, bolt or scredriver.
That should return everything to normal. Assuming that there are no broken or bent parts in your clutch mechanism.
I hope you find this solution helpful. Please rate it and thanks for using Fixya. Good luck!
Sep 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Jun 02, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
May 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Last weekend I sharpened the blades, changed the oil filter, the oil, and the spark plug, put in fresh gas and started the mower up and mowed the lawn no problem. This weekend, it started right up but when...
There is an operator presence switch under the seat...if the mower shuts off when you release the brake, this switch is faulty and must be replaced
May 02, 2009 | Garden
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
400 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
