Question about Frigidaire ATF6000ES Front Load Washer
My washer is not spinning but water comes in and is pumped out. Nancy
    Problem Solver:
Had the same problem, it was doing everything it should until it got to the rinse and spin. It was draining but slowly then wouldn't spin. We found it was a clogged drain pump. We cleaned it out and now its like new. Try reading the codes.
Posted on Sep 24, 2009
Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Jan 31, 2010 | Asko W6021 Front Load Washer
My washer won't spin the clothes dry
your pump in your washer is malfunctioning. no matter how much it spins if the pump doesn't work it can't remove the water. it will just flow back into the tub once it stops spinning.
Dec 18, 2009 | Cars & Trucks
Washer won't spin or drain water
Sounds like a blocked pump (turn on, advance thru to spin, press start- do you hear a humming noise? if yes, pump is blocked).
Disconnect from power.
Manually bucket as muh water out of machine as you can. Then lean machine over so you can access underneath machine.
Drain pump located right front- it has a kind of fan blade at the bottom. This fan blade should turn very easily- if not, there is a blockage.
-To remove pump, remove plug wires from pump (1 plug with 2 wires, 1 plug with 1 earth wire). Then there is a white plastic tag located at the top of pump-pull this gently towards you, and turn whole pump assy anti-clockwise. Pump assy will drop out easily- do not force (note- water will come out too- put down some towels!!) Remove any blockage from pump, and reach fingers into bowl where pump has come from to check for any blockages. If OK, reassemble and retry.
Aug 08, 2009 | Fisher and Paykel GWL11 Top Load Washer
Simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
simpson washer 22S950 not spinning..not agitating..water pump works...L6 come on the screen...bipps most of the time...part of numbers missing on the screen..
Jun 22, 2009 | Washing Machines
Washing machine wont wash screen says test.
Its a draining problem.the drain pump is either got blocked so needs cleaning or the drain pump is faulty and needs replacement. --------------------------- If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jun 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
GE Profile top load washer purchased 2003 water comes out from under washer when spin and drain cycle on. this not mentioned in trouble shooting area. think it is water pump or whatelse can it be?
It has to be in the water exit path somewhere - is there a pump sump inspection? Is there a hose split? Likely the drain hose, or where it connects to the machine. Has the pump split open? Can you remove the machine cover and inspect it while it is doing a cycle so you can see where the water is coming from?
Apr 26, 2009 | Washing Machines
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Avanti W797: Tub won't spin or water does not empty.
Had the same problem. The water pump is not working and since it cant drain water it wont spin. A easy fix. There's a magnet located on the water pump thats comes lose. Simply tie it back into place.
Nov 20, 2007 | Avanti Top Load Washer W797
Frigidaire ATF6000ES Front Load Washer Logo
122 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
