Question about Kitchen Ranges
The steel gas tube that feeds gas to the oven corroded and now leaks. have not been able to find the proper tubing to replace it. It is 7/16 steel tubing.
  • 546 Answers
THIS IS A VERY DANGEROUS SITUATION!!SHUT GAS SUPPLY OFF IMMEDIATELY. now,remove corroded line and take it to a home improvement store to find a replacement,or call the GAS COMPANY for assistance.
Posted on Sep 24, 2009
  • rtpflh
    rtpflh Sep 29, 2009
    so glad to see you responded.cook safe!
Why when i go to put gas in my car does it start spilling out every where
Down tube leading into tank has a rubber connector that may have gone bad. Either that or another leak in that tube.
May 20, 2014 | 1997 Chevrolet Malibu
Tip
Air To Water Heat Pipe Heat Exchanger
General Information
Air to water heat pipe heat exchanger is mainly to heat water using the hot air from heat recovery, it can be used for domestic water, water for boilers or production process. The exchanger is constructed using a partition in the middle to separate the exchanger, both sides are independently sealed. A single heat pipe can be replaced. While working the hot air flows from one side to the other side, the heat pipe absorbs heat. Meanwhile, cold water flows from the reverse side, the heat pipe releases heat, thus heating the cold water from the reverse side. The outlet temperature is not lower than dew temperature.
Field of Application
-feed drying
-cereals and oil processing
-chemical industry
Specification
Advantage:
-high heat recovery efficiency
-seldom temperature difference, fast heat starting, good isothermal
-the speciality of the heat pipe results in a high wall temperature, exhaust gas temperature can be reduced without reaching the acid dew point, avoid the corrosion of the equipment.
Core tube material: stainless steel, carbon steel
Fin material: aluminum, stainless steel
Tube/fin bond: extruded, high-frequency welding
Tube arrangement: staggered
Core tube external diameter: ?25
Core tube wall thickness: 2-3mm
Fin thickness: 0.4mm
Fin height: 12.5mm
Fin spacing: 3mm
Temperature range: 20~150?
Order Information
P/N Description: HP-XYZ-N
Note: X should be replaced into S, C
Y should be replaced into S, A
Z should be replaced into ET, W
N means the power needed
S-stainless steel
C-carbon steel
A-aluminum
ET- extruded
W- high frequency welding Air To Water Heat Pipe Heat Exchanger
on Dec 14, 2016 | Miscellaneous
I replaced the water valve and now the connection that feeds the ice traye leaks
The tube isn't pushed all the way in. You should feel it pop into place when you put the tube into the valve.
Mar 25, 2013 | LG LFX25960ST Stainless Steel French Door...
Fix leaking fuel line
What Vehicle?
What kind of repair-steel tubing,plastic tubing or
braided steel.
Nov 30, 2012 | Cars & Trucks
Small pin-hole in the water intake tube the feeds into the fridge
You can cut the bad spot out and use a connector to splice them together. You could replace the whole line but that is time consuming and a pain.
Nov 03, 2012 | Bosch Evolution 800 B20CS80SNS Stainless...
Husky model WL6605-00AJ,will pump up to 65psi,thats all the air showing on thr gauge.The compressor is still running
You Might Have Water Condensation Inside The Tank Therefore It Can Only Fit So Much Air Into The Tank Which Is Why Its Always Better To Completely Drain All The Air Out Of The Tank When Not In Use.
Mar 17, 2012 | Air Tools & Compressors
Oven wont work but range top does
Your range has a small 3"x1"x1" metal box with a gas valve going into it placed right behind the broiler flame tube; this gas safety valve alows the gas to enter the "pilot" tube to be lit by an piezio electric ignitor: that is the clicking you hear when you try to operate the oven. this gas valve needs to be replaced as, it is not opening to feed gas to the ignitor. an appliance parts store will have the oven gas valve; it just screws into place. be sure to turn off the gas and, remove power to the range before you do any work on it.
Apr 06, 2010 | Magic Chef 31000 Gas Kitchen Range
When trying to start the bike. Gas leaks out of
That's probably the overflow/flooding tube. Try starting it without the choke and/or with partial choke..Yea floats are stickin or needles are dirty..Good Luck..Tim
May 08, 2009 | 2002 Hyosung GV 250 Aquila
Oven only works at max temp
The oven temp switch should be replaced.
This switch has a long tube which goes from the switch to the inside of the oven. The switch can be replace without much of a problem but, feeding the new tube down to the oven can be tricky sometimes. The old tube will come out but you have to find the same hole to put the new tube back through, sometimes this will go through insulation and you can't see the hole where the old tube came out. It's not hard to do just be aware of this problem.
Dec 16, 2008 | Ovens
Dynasty range, oven does not heat up enough
30 inch oven has only one oven tube, 36 inch oven has 2 burners in it, most comment is the oven ignitor is out. If you have 2 burners, I'll change both oven ignitor at the same time, because they worked together. also check the oven tube, if it is corroded at the ignitor area, change the burners. Have fun.
Mar 22, 2008 | Dynasty DGRSC 30 Gas Kitchen Range
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
