Question about Frigidaire ATF6000ES Front Load Washer
Can't finish a cycle
We just bought a front load frigidare two days ago. We have never had a load finish a cycle. It starts fine then after a few minutes it stops and says ERR 70. There is no description in the manuals of what the error codes mean. Is the washer defective or are we using it wrong?
  • Anonymous Mar 15, 2014
    This happens and usually I just put on respin and the cycle finishes but now it is happening more often. I had to take out my load for the cycle to finish the last time. I understand this means something is clogged? How do I go about unclogging? Do I have to call someone or can I do this myself?
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Dec 29, 2007
My Maytag Neptune Front load washer walks in the spin cycle (MAH8700A*
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
May 26, 2014 | Maytag MAH8700A Front Load Washer
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
When i push the start button nothing comes on,if i unplug the machine and plu it back in the machine works fine for a while than stopes working
You need to offer more info for us to assist with possible fault.
When you say unplugging/re-plugging it allows it to work for a while, please explain - do you mean it works for a few minutes, it for a few hours or for a few washing cycles/days? Does it stop part way through a wash, or once started will it always finish a wash before failing again?
Dec 15, 2013 | LG Wm2688hnma Front Load Washer wm2688hnma
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet Washer - Problems with the Spin Cycle
you might want to call whirlpool cause it might be still in warranty
Dec 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replace both the main control board and the wax motor. This sounds like a computer chip malfunction
As far as the squeak, make sure it is not the bearing located at the back of the tub under the large pulley.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Can't get washer to finish spin cycle
I'm not familiar with this washer, but if there is water in the drum when it comes to the spin cycle chances are that it won't spin. The likely cause of water left in the drum would be that it is not emptying fast enough, so you might check the pump for a blockage, or if there is a filter check that for some obstruction like fluff, coins, or small items of clothing which can sometimes get drawn through from the drum. Tom.
Mar 09, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
