Question about Flotec Plumbing
How to prime flotec drill pump - Flotec Plumbing
  • 67 Answers
Fill the hose that will be draining and run the drill in reverse for a second then forward.
Posted on Sep 24, 2009
  • 16 Answers
SOURCE: how do i prime a flotec electrical well pump.
remove plug in top of pump or plumbing. fill with water u may have 2 repeat sev. times
Posted on Dec 08, 2009
  • 6 Answers
SOURCE: i have a flotec water pump that sits on top of my
if the pump is working correctly, it can either be, need more water to prime it, or something in the well, such as low water, plugged filter, etc....sometimes when you have a system that is intermittently used, it can take 20 or 30 minutes of continuous priming to get it to pull, enough water to maintain the prime.
Posted on Apr 06, 2009
john224
  • 1378 Answers
SOURCE: directions for the flotec drill pump. do I need to
No you do not. Those pumps are rotary vane designs and will prime themselves as long as there is no suction leak between the liquid being pumped and the pump inlet.
  • 119 Answers
SOURCE: I have a flotec 47013 and would like to know how to prime pump
you need to fill the hose or pipe with water then put the pump on and it should work.
Posted on Apr 19, 2010
  • 5603 Answers
SOURCE: my flotec well pump will squirt water and then
Check for an air leak in your siphon line. It can be very small and totally prevent the pump from priming.
Posted on Jun 08, 2010
Looking for shift sell for Flotec: FP5162
I've never heard of a shift sell for a flotec water pump. That is if you are looking for a part for a Flotec sprinkler pump. Maybe you're looking for a shaft seal.If you need parts or a manual you can look at www.flotecpumps.com The flotec part number for the mechanical seal and gasket kit is:5PP5000. You can search their web site for local suppliers, I'd call first to see if they'd have part in stock. Follow directions when installing. Do not use oil or grease to lube new seal. Liquid dishwashing soap is best.
Jul 12, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
My flotec well pump will squirt water and then stop . I keep feeding it water slowly but it won;t prime. What should I be doing?
Jun 08, 2010 | Flotec Corrosion Resistant Shallow Well...
Apr 01, 2010 | Plumbing
How do I remove the impeller from my Flotec pump?
I called Flotec and they provided perfect instruction. Opportunity solved.
Dec 07, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
How do i prime a flotec electrical well pump.
Dec 05, 2009 | Flotec Plumbing
Directions for the flotec drill pump. do I need to prime it ? how ?
Sep 24, 2009 | Plumbing
I have a flotec water pump that sits on top of my pressure tank, pump worked ok last season, and when we tried to prime the pump to start this season, it wont pull water up from the well pipe, pump will...
Apr 06, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec Sprinkler Pump not priming
it might be that the pump is prewired at 230 volt and you are running a 115 power supply to it, if motor just humms and little water comes out this might be your fix
Mar 13, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Need to replace impeler on flotec pump
Contact flotec directly for impeller tollfree 1-800-365-6832
or they may have been acquired by Pentair so try
PENTAIR WATER
STA-RITE INDUSTRIES
200 Tate Street
Union City, TN 36261-024
(800)-800-468-7867
(FAX)-800-390-53
Feb 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Plumbing Logo
812 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
