Question about HP Office Equipment & Supplies
Black cartridge into color cartridge slot, now stuck, what to do?
    Scholar:
  • HP Expert
  • 199 Answers
You can see three locks are there in the bottom of the carrage block.just release the three locks and remove the cartridge
Posted on Sep 24, 2009
How to install ink cartiges
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Aug 27, 2011 | HP Photosmart C4280 Aio Printer
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
slot on the left.
5. Pull the print cartridge towards you out of its slot.
container.
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I have an HP OfficeJet V40xi. My problem was getting an "cartridge black installed error" but it was properly installed! I am not try replacing with other cartridge yet...that might it be the...
The cartridge slots are not interchangeable so you will not put the color in the black etc.
Many HP printers will detect third party and re-filled ink cartridges and refuse to accept them. There is no way to override this in the software package.
I had a third party re-man ink cartridge work for two days and then the HP decided it didn't like it.
Apr 15, 2011 | HP OfficeJet V40xi InkJet Printer
How to load the ink cartridge
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Put new black and color cartridges, will not print only black lines or when I use color, just color lines, I am only using copying not hooked up with computor , juststand alone copying
Maybe the printer need to clean a slot for a catridge. Because that printer stuck with old tint in the head for a printer therefore it need clean the heads.
Nov 27, 2010 | Lexmark X5150 All-In-One InkJet Printer
Mixed up the ink cartridges and now they are stuck
Turn the printer ON. Open panel to the right of feeder tray. Using something to leverage if necessary, apply pressure to front edge until it tilts outward and then slide it out.
Then you can push the replacement cartridge into position and close the panel. Unplug and plug back in the printer to reset the printer.
Apr 12, 2010 | HP Officejet 5610 All-In-One InkJet...
Ink is stuck in the printer. I can't get it out.f4280 deskjet
I found this on the HP Web Site. You can download the user guide and the Manual. Show step by step instruction to change the cartridge. If you find this helpful pls rate me.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3390949&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
1. Make sure the product is on and you have letter or A4 unused plain white paper loaded in the input tray.
2. Open the print cartridge door.
The print carriage should move to the far right side of the product. If the print carriage does not move to the right side, turn the product off, and then on.
3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
2 Print cartridge slot for the black print cartridge
4. Pull the print cartridge towards you out of its slot.
6. Remove the new print cartridge from its packaging, being careful to touch only the black plastic. Gently remove the plastic tape using the pink pull tab.
7. Slide the new print cartridge at a slight upward angle into the empty slot. Then gently push on the upper part of the print cartridge forward until it snaps into place.
If you are installing the black print cartridge, slide it into the right slot.
Jan 28, 2010 | HP DeskJet F4280 All In One Printer InkJet
I put the black cartridge #56 into the tricolor in an HP 5610 Off
It just is "jammed" into place, like a round peg into a square hole.
Use a bit more strength, in order to "unjam" it.
Or, if you are not comfortable, take it to a qualified printer technician,
and let him/her remove it.
Nov 19, 2009 | HP Officejet 5610 All-In-One InkJet...
Color cartridge stuck
PULL AND THEN CLEAN THE SLOT WITH RUBBING ALCOHOL TO GET THE COLOR OFF THE BLACK SIDE. REMEMBER TO UNPLUG WHILE CLEANING. THEN CLEAN THE CARTRIDGE WITH ALCOHOL TOO. THEN PUT BACK IN RIGHT PLACE AND YOU SHOULD BE GOOD TO GO. IT MAY TAKE SOME FORCE TO GET IT OUT. BUT REALLY NO CHOICE NOW. HAPPY NEW YEAR TO YOU.
Jan 06, 2009 | HP LaserJet 1300 Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
