Question about Epson Stylus RX680 Color All-in-One InkJet Photo Printer
Epson RX680-How to print only in B+W
Epson RX680 conundrum: One of the "light" colour cartridges is empty and shuts down the whole printer unless replaced. How can one print simply B&W?
    President:
  • 1,187 Answers
You can set it to "grayscale" and supposedly print only in black/grey.
However, Epson printers use a small amount of every color even when printing black only or greyscale (black). Your printer will still not work with one color tank empty.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95907
Here is how to set it:
Open the properties page for the RX680 and on the "Main" tab, click on [Advanced]. A Note may appear egarding incorrect settings.
Click [Continue]. Find the [ ] Grayscale box and check it, the [OK]
[OK], etc.
Here is Epson's note on using grayscale / colors:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95908
Posted on Sep 24, 2009
I have an Epson RX680 the black and yellow ink are not printing after trying several print head cleanings and even replacing the cartridges (even though they were better then half full)
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Nov 15, 2012 | Epson Stylus Photo RX680 Printer
Will the Epson cx3900 print if one of the coloured cartrige is empty
No unfortunately the printer will not print unless all cartridges are present and have an adequate supply of ink inside them. Even if your only printing black and the black cartridge is there and full, it will still need the color cartridge ot be present and partically full of ink in order to print.
Aug 15, 2011 | Epson STYLUS CX3900 All-In-One InkJet...
The blue colour has run out but the black is fresh and it won't let me print a black text document-is it possible with out having to go and get a blue cartridge?
The Epson DX4850 will print black only. You can find a check box in the settings to Print Black only in the advanced options.
This works fine for me when all my colours are empty.
Jan 18, 2010 | Epson Stylus DX4850 All-In-One InkJet...
Can't scan when out of ink
Unfortunately, there is no way to print with your printer without replacing
the empty cartridges. Sadly, that's just how Epson printers work.
Jan 16, 2010 | Epson Stylus CX5800F All-In-One InkJet...
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson 1290 - I just want to print in black and white
Unfortunately, Epson printers demand that both black and colour cartridges are OK before the printer will work at all. Now, if you are really sure that you only want to print black, the most cost-effective solution for you is to buy an Epson Chip resetter on E-Bay. This will reset your empty colour cartridge to "full", as far as the printer is concerned. You can then happily continue with your black-only printing.
Feb 01, 2009 | Epson Stylus Photo 1290 InkJet Printer
Epson r265
Check status monitor if empty or low:
Replace if empty ect:
Soak the cartridge nozzles upright in Flush Solution for 6 hours dry and retry , make up a A4 Paper colour printing page with each colour band about 1" high x 8" wide and print out 4 - 6 pages checking which colour band is poor:
Keep printing if improvement noticed:
if not
Resoak the offending cartridges and repeat:
also can
Use cleaning cartridge on offending colour slot/s then retry:
Dont use the head cleaning utility to much as it is programmed to disable your printer after a pre-set number of cleans and will have to be serviced:
cx3200@tiscali.co.uk
Dec 21, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus RX680 Color All-in-One InkJet Photo Printer Logo
311 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
