I'm looking for a replacement convergence board for my Jvc AV48WP74 tv.SSB-5068A-M2
I've replaced the STK392-150 ic's already and after a week they failed again. JVC does not return my calls.
A Google search for the board part number returned several sources. Here's one. You should also check the values of resistors around the STK's. When the IC's fail, the resistors can change value which can cause the repeat failure you're experiencing.
I have a JVC AV-48WP74 rear projection big screen. It has convergence problems. I've changed...
(More)
I have a JVC AV-48WP74 rear projection big screen. It has convergence problems. I've changed convergence IC's before and this time it is not working out for me. I have put in two sets of brand new convergence ICs and they have had the same out come. It will not power up, the power light just flashes but if I put the original ones back in, it powers up fine. The convergence is off but it powers up. I've changed any bad resistors but if the original ones work then that cant be the issue. My supplier said that he could send me new ones but he doesn't think that it would solve the problem. What could the problem be?
I have a JVC 48 inch tv. I've had it for a few years. Today I was watching football and the TV...
(More)
I have a JVC 48 inch tv. I've had it for a few years. Today I was watching football and the TV sizzled and turned off. I unplugged everything and turned the tv on...same thing. Where is the problem ? Is it fixable ?
