Question about Samsung SGH-A877 Impression Cell Phone
The touch screen on my phone is so messed up that i cannot manage to hit menu or anything i want to chose. where i tap my finger, it clicks another thing way up on the screen, is there a way to reset everything without using the touchscreen ?
I NEED A WRITTEN MANUAL FOR SETTING UP MY CELL PHONE WITH STRAIGHT TALK
try: straighttalk.com for instructions or
call straight talk from another phone
Sep 28, 2016 | Cell Phones
Screen is stuck fully expanded on startup screen
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
/uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Mar 27, 2015 | Apple iPhone 5c
Mf190 driver for android
Instructions
    • 1
      Pull the battery out of your Android phone if an app freezes while you are using it. Reinsert the battery after one minute. Replace the battery cover and restart the phone. Launch the app again.
    • 2
      Check whether your phone's data connection is active if the app is data-dependent. Touch "Menu," and then tap "Settings." Touch "Wireless & Networks," and then tap "Mobile Networks." If the "Data Enabled" field is not checked, touch it to enable it. Launch the app again.
    • 3
      Verify that the app is up-to-date. Touch "Market" from the phone's home screen. Press "Menu" on your phone and touch "My Apps." Scroll down to the "Not Installed" section. If the app has an available update, touch the app. Tap "Update," and then touch "Accept and Download." Wait for the update to complete, then launch the app.
    • 4
      Uninstall and reinstall the app. Tap "Menu," and then touch "Settings." Touch "Manage Applications," and then tap "All." Touch the app that is not working, and then tap "Uninstall." Reinstall the app from the Android Market and launch the app again.
God bless you
May 24, 2013 | Cell Phones
Can not get password to use on iPad or iPhone to work using password
If you are asking about the passcode that locks your iPad or iPhone so others can not access it, following the steps below.
-Start with the iPad screen off.
-Press the HOME button (the small circular button close to the screen)
-Slide to unlock the screen, at the bottom.
-Press the HOME button until you see a box that says SEARCH IPAD (the keyboard will also slide up when you're on the correct screen)
-In the box that says SEARCH IPAD, type SETTINGS
-At the top of the list, created by typing SETTINGS, should be the TOP HIT of SETTINGS.
-Select SETTINGS by tapping with your finger.This will open the SETTINGS app.
-On the left hand side of the two columns, in the SETTINGS app, should be a list of options. Select the GENERAL option from the list by tapping it with your finger.
-On the right hand side of the columns should now be a list of more options starting with ABOUT.
-Continuing looking down past the ABOUT option for the option PASSCODE LOCK.
-Select the PASSCODE LOCK option by tapping it with your finger.
-A new menu, on the right hand side, should now appear starting with the TURN PASSCODE ON option.
-Select the TURN PASSCODE ON option by tapping it with your finger.
-The SET PASSCODE pad should appear in the center of your screen. Enter a four digit passcode of your choice.
-Reenter the passcode you chose again.
-You are done! The next time your iPad times out or you lock the screen, it will require the four digit passcode you set by following the above steps.
Oct 19, 2012 | Cell Phones
My icons are too big and i cant reduce the size???
Please follow this steps to set back the font size or icons of your Iphone.
* Tap the "Settings" menu from the iPhone home screen.
* Tap "Accessibility."
*Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
*Return to the iPhone home screen.
Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Thank you for visiting FixYa...
Aug 03, 2011 | Apple iPhone 3G
Icon very big how can i make it small
First of all try this: Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
If it doesn't help, follow the steps below and repeat the above (step 5.)
  1. Tap the "Settings" menu from the iPhone home screen.
  2. Tap "Accessibility."
  3. Tap the word "Off" next to "Zoom" to turn the Zoom feature on.
  4. Return to the iPhone home screen.
  5. Tap the iPhone with three fingers twice in succession. The home screen icons will be magnified to 200 percent. To adjust the zoom level, touch the screen with three fingers then move them up to increase the zoom, and down to lower it. The next time you tap the screen twice with three fingers, the iPhone will automatically return to your custom zoom level.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 09, 2011 | Apple iPhone 3G
How to fix screen calibration on the phone?
Go to Menu>Settings>Phone>Calibration
Note: it doesn't always calibrate on the first touch on each point. It might take you many tries to get it to move to the next point.
It is best to do this operation with a Q-tip, which resembles a finger to the Eternity's software more than a sharp point, but is also more accurate than a finger.
To test the calibration, dial *#0*# and press "9"
If this did not fix your problem, or you think you have a hardware issue
Feb 28, 2011 | Samsung Eternity Cell Phone
Menu icon on screen can't reduce to normal
Simply use 3 fingers to double-tap on your iPod's screen to put everything back to their normal sizes.
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Jul 28, 2010 | Apple iPod touch
My iphone menu screen enlarged by itself, and now ...
Don't worry. Maybe your not using enough fingers (literally).
You have to double-tap the screen using 3 fingers to zoom out or put it back to its normal size.
May 20, 2010 | Apple iPhone 3G
Samsung SGH-A877 Impression Cell Phone Logo
1,019 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
