Question about Frigidaire GLTR1670A Front Load Washer
Buzzes will not spin
I think that it was overloaded..... door popped open during wash.
I took some clothes out, but now it just hums and will not spin at all.
The door lock light stays lit but the wash lite goes on and off.
  • NURSE28 Dec 31, 2007
    I HAVE THE SAME PROBLEM BUT I EMPTIED THE MACHINE AND I PUT THE WASHER ON DRAIN AND SPIN AND IT DOES NOT DO ANYTHING BUT HUMM...
    President:
  • 1,294 Answers
Plug off the wall, check behind for the belt may have come off.
Posted on Dec 21, 2007
Drier makes humming noise, and won't spin
check for a problem start/run capacitor for the motor
there may be a overload button that has popped out
Jan 09, 2016 | Washing Machines
Washing machine won't spin, drum, belt and pully won't move at all
It could be that the overload switch on the lid hinge is stuck in the off (lid open) position, or that the motor start capacitor has failed (if you hear a hum or buzz when you try to start it)
Jan 26, 2014 | Frigidaire ATF6000ES Front Load Washer
Washer filled w water but wont agitate,spin or drain. I hear a humming,buzzing and something smells like it is burning. After several attempts to start in various different cyles it may have tripped...
send the model number.if it's humming it sounds like the motor is bad.where.if it resets after a while and hums again it's the motor.there's an overload in the motor,when it gets to hot it pops and will reset after it cools.
Apr 13, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Loud buzzing and no spin. No codes.
Fixed mine!!!! I just took out the comforter and left the sheets in the washer, after i shut the door it started right up. I guess it was overloaded and that is how the machine reacts to an overload. Whew!! Saved a call to the plumber$$$$
Feb 13, 2010 | Frigidaire Affinity ATF6000F Front Load...
Kenmore TL Washer Just Hums
try to wash by 1/2 load the same cycle maybe the problem come from overload laundary
Jun 06, 2009 | Washing Machines
Clothes have holes from getting caught in seall during spin cycle
YOUR OVERLOADING UNIT,,CLOTHES SHOULD ,,FLOP LOSELY..TAKE A LOOK A THAT DOOR BELLOWS AND MAKE SURE ITS NOT WARPPED ,,PITCHING TO FAR TO THE INSIDE OF UNIT,,ONTHEJOB..
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Jan 05, 2009 | Amana ALW480DA Top Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during...
this is a direct drive,no belts,good washer you won't find any washers built like this anymore,on top console pop off the clips on each side,then remove the two phillips screws,lift the top console,with a regular screw driver stick in into the hole where the clip goes into frame and on top of the clip and push forwards and the clip will pop out,then there's a lid switch a white wire connector on the right top,unplug it,now grab the cabinet and tilt it up and pull back and remove the cabinet.if the motor is humming and it's not draining it sounds like some thing is stuck in the pump or a bad pump,look down and you'll see the pump on the front of the motor,with a screw driver pop off the two clips and slide the pump off,get a piece of wire and stick it into the white connector where you disconnected the lid switch from,this will jump out the switch,set the timer to spin and run it,if the motor spins then you know the pump is jammed or bad.let me know what you find.the pump part is WP3363394
Oct 02, 2017 | Whirlpool LSR7333 Top Load Washer
Washer making buzzing sound during spin cycle,then stopped during wash still has water in tge clothes,buttons light up as if going to work but nothing happens jusy buzzing noise
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Jul 21, 2008 | Frigidaire Washing Machines
Frigidaire GLTR1670A Front Load Washer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
