Question about Fujitsu Computers & Internet
Watson client has stopped working every time i try and open device manager
Posted on Jul 25, 2011
I was having a Watson Client problem... and today I get: Exc in ev handl: Error: Bad NPObject as private data! What's up with this, now! Still having Watson Client problem and can't open Word! Help
This is a virus ..I suggest to reinstall the program ..and remove the old one completely ..If this will not fix the issue you will have to reinstall operation system to fix it for good.
Dec 24, 2011 | Computers & Internet
How to fix Watson Client not working on pc
I have had the same problem one, two many times. I brought it to a pc repair shop over and over again and still the same. I have paid over and over equaling up to a total of $300. I looked else where and found out that I can repair this all on my own. You can too, just check this out HERE
Dec 22, 2011 | Microsoft Windows 7 Professional 64 Bit 3...
Menu keep on poping up when tried to exit it goes back on the screen over and over.
Try uninstalling a few unnecessary programs
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram
or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
click start right click on my computer,properties advanced scroll down to system and recovery open settings write and debugging information the drop down button select none
ideally, it should already be the default debugger for your system.
The Dr. Watson debugger program logs all information related to failed processes to the Drwtsn32.log file. In addition to this, the debugger program can be configured to create memory dump files related to the failed processes. You can refer these dump files to analyze the reason behind a process failure.
Perform the following steps to configure Dr. Watson as the default debugger program to record user-mode program errors:
  1. Open Start menu, select Run, type Drwtsn32.exe -I and then press Enter. This command sets Dr. Watson as the default debugger.
  2. Next, run the Drwtsn32.exe command.
  3. In the Dr. Watson for Windows dialog box, select the following check boxes:
    • Append to Existing Log File
    • Visual Notification
    • Create Crash Dump File
  4. Now, when your computer restarts after the STOP 0xC000021A error is generated, run the Dr. Watson command.
  5. Here, view the paths to the Dr. Watson and User.dmp logs.
  6. Open Windows Explorer, navigate to the log files and then open them.
  7. Here, check the cause behind the STOP 0xC000021A error.
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
another one of the possibile reaons is
a bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to finish its cycle and have an end so any faulty leads will end up with a computer error
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
Apr 04, 2011 | Computers & Internet
I have the Acer Aspire One. My sound works however, every time I try to use Skype a blue screen comes up and it restarts the computer. As well when I play music it always skips and there is a static noise...
The first cause can be fixed rather easily. Simply run fewer programs or buy additional RAM or processor upgrades. Your computer is running past its specified limits. But remember that in this case the blue screen of death should happen extremely infrequently. If you see the physical memory dump blue screen much more often then the issue is clearly...!..
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Apr 03, 2011 | Acer (54.AA806.001) Sound Card
All my windows microsoft programs have stopped working and watson client stopped working keeps coming up
If you made any recent changes - installed new software or drivers - then try a sytem restore to restore to an earlier point, when you think the laptop was working. You should also check for viruses.
Mar 09, 2011 | Computers & Internet
I have almost same problem. This problem start one time when I using my computer. Computer always stop after trying restart, sometimes start normally and stop after few second. And now when I start...
hope this helps
Feb 25, 2011 | Abit KV8 Pro Motherboard
My touch pad constantly freezes and is inhibiting my work flow due to restarting the notebook all the time. please help
hope this helps
don
Feb 23, 2011 | Computers & Internet
I can't use Word...I keep getting a box indicating that "watson client has stopped working"...what can I do?
  2. hope this helps
Jan 22, 2011 | Fujitsu Computers & Internet
After shutdown my computer i see blue screen saying: stop c000021a fatal system error, please solved this problem.
Most of the time, this error occurs due to the failure of the Winlogon.exe process. This usually happens if a faulty third-party Graphical Identification and Authentication (GINA) DLL exists on your system. GINA is a replaceable DLL component that is used to perform the following tasks:
  • Implement the authentication policy of the interactive logon model.
  • Perform user interactions, such as authentication and identification.
At times, a remote control software may replace the default GINA DLL file, msgina.dll, on your computer and you may face the stop error. This is the reason why it is a good idea to first check if you have a third-party msgina.dll on your computer. To do this, run the regedit command to open the Registry Editor tool. Here, navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
Here, check if the value GinaDLL REG_SZ is on the right pane. If the value is there and its value is different from msgina.dll then it means that a third-party software has changed this value. In case this value is not there, it implies that that your system uses msgina.dll as the default DLL file for GINA.
If this error follows a new driver, service or third-party software installation, you must try to uninstall this new software to repair the error. To do this, you may use a good third-party program uninstaller tool, such as Perfect Uninstaller to ensure complete removal. You may also try to install an update for the software, if it is available.
You may also try to boot your computer with Last known good configuration information to see if the error goes. If nothing works, you may have to perform and in-place upgrade of your operating system to resolve the error.
utmx_section("bottomad") Additional Recommendations...
Driver Update: Many errors are related to driver problems such as obsolete, outdated or incompatible drivers. A driver update tool is recommended to scan your system for corrupted and outdated drivers and to ensure that all your drivers stay up-to-date.
hope this helps
Nov 17, 2010 | Computers & Internet
Dell Latitude and buffalo client manager problems
I have just had exactally the same problem,
Right, what you need to do is, go to "help & support" for the start menu, when that has loaded search device manager.
Then click on the first [yellow] question mark you see under "network adaptors". The it will come up as, a property box, then click re-install driver, during the process of re-installing a box will appear, like mine did as we both have the same computer/laptop,saying something like; "window's dose not support this" there are 2 options continue installation or stop, click continue & then go to client manager and see wether your wireless card been picked up, if that failed try clicking other question marks & re-installing then. It may be related.
Dec 27, 2007 | Buffalo Technology Buffalo AirStation...
Computers & Internet Logo
3,199 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
