Question about Refrigerators
My refrigerator is not cooling on both sides icleaned the fan and coil in the back and the inside was frooze up . idefrost it and it word for three weeks and doing it again what up with it ?
  • Mike Smith
    Mike Smith May 11, 2010
    No one can help you without you giving the complete model number of your refrig .
  • 4,066 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 24, 2009
GE DL213908 Side by Side Refrigerator not freezing or cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Refrigerators
The top freezer is working but lower part refrigerator compartment doesn't cool at all even adjusting temperature to Max cooling??? It is like fan doesn;t blow cold air from the freezer
Hello Eddie111,
If you were to remove the rear panel on the inside rear of the freezer you would then be able to gain access to the evaporator coil, If when you gained access to the evaporator coil you then noticed any ice build up on the coil itself this would be called a defrost issue that your unit was having. This is usually due to one of three parts either the defrost thermostat, the defrost heater, or the defrost timer or in some units the adaptive control board would be showing a fault. Would need you to message me back further if you do have a defrost issue with your unit. There is also a small damper door that lets the evaporator fan motor blow cold air into the refrigerator side of the unit this damper door is controled by a thermostat that is found in the ceiling of the unit. Usually attached to the control knob that is located inside the freezer. So first thing to check for is that the fan is working on the inside of the freezer next thing would be if you have the defrost issue on the evaporator coil itself, and lastly you would check the damper door and the thermostat inside the refrigerator side of the unit. If you have any further questions message me back with your reply to the defrost question that I asked previously. Thanks again I await your reply
Rick
Jul 20, 2011 | Kenmore 64802 Top Freezer Refrigerator
Ge GSS22KGMD not cold at the top of freezer or making ice. Bottom of freezer is cold
jharper is correct....the fan in the freezer must not be working . Replace the main control board..pt # WR55X10942 , as this supplys the dc voltage to the fan motor .
Aug 24, 2010 | GE GSS20IEM Side by Side Refrigerator
Whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Jul 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Freezer is not freezing and refridgerator is not cold enough
A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Sep 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Side by Side Can't find model # Not cooling enough
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
  • The defrost timer
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
