Question about Dryers
Maytag MDE5000AYW huge expense to heat it!
My electric bill just soared. we have checked everything and it comes down to the dryer. What is the typical usage? What do I need to check to see why it is malfunctioning and going so high?
  • 304 Answers
Typical Dryer Heater wattage is around 5,000 watts or 5KW multiplied by the amount of time you run it. For instance 5000 watts for one hour is 5 Kilowatt hours multiplied by your electric rate. This gives you a cost for running it for one hour.
However, your heater runs more when the clothes are wet but less and less as they dry. A thermostat turns the heaters off around 160 Deg and back on at about 135 deg for normal heat. As your clothes get closer to dry the heater reaches 160 faster and 135 slower so that the on time is continually decreasing.
All this cycling translates to a heater on time of about 70% total I'd guess. Even if your vent line was blocked your heater on time would decrease due to safety systems turning the heater off to prevent fires.
All that being said you can approximately calculate electricity use as 5 KW multiplied by the amount of time you ran it and that number multiplied by 70% to account for heater off time. For a 5000 watt heating element that would be 3.5 KW multiplied by your electricity rate per KW. Adding a 5 amp motor that runs all the time would make the figure about 4.1 KW.
If you're still following me you need to keep track how many hours you dry clothes for the month and multiply the final number from above by that.
Let me point out the things that use a lot of electricity and you can hopefully pin down one or two you can affect. The things that use the most power have heating elements in them:
  1. Stove
  2. Dryer
  3. Electric Heating
  4. Air Conditioner
  5. Electric Water Heater
  6. Dishwasher with heated water and heated dry
  7. Refrigerators and freezers with self-defrost feature
Keep in mind that having company for a week or lots of family members will affect all the numbers. Your utility company usually offers a free (part of the rate structure) service that will help you track down high usage if you have an unusually large bill. Consider asking their assistance.
Posted on Sep 24, 2009
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Stopped heating up. Gas is on and everything works but the heat doesn't come on.
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 17, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag neptune will not heat up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Dec 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Wont get hot
Nov 18, 2009 | Maytag PYE2300AY Electric Dryer
Heating element drawing lots of power, big bill power
Well a dryer heating element does draw quite a bit of amps(that is why it is 220) but it cycles on and off & it is not an appliance that is used everyday. The first think I would do is read the electric meter and verify that it was not misread before condeming the dryer. If the electric meter reads are correct then it is possible it could be the dryer heating element shorting. How much do you actually use the dryer? Is the heating in your house electric and have you been using it? You could also have your electric company test the meter. Look at your usage of electricity for last year at the same time(it will be on the bill) and see what the number was.
Oct 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
My Maytag electric dryer failed to dry cloths due failed heating element. Air is cold in all settings. Air is pumping out well through the vent on the back.
Sep 14, 2009 | Dryers
Clothes coming out of dryer with oil stains
Some thing was put in there with it on them you just need to clean it out thank you for useing fixya rate me
Apr 07, 2009 | Maytag Atlantis MDE5000 Electric Dryer
Maytag Dryer will not start again
Check list:
clear vent pipe
dryer clean of lint
blower wheel tight
drum turns freely
fuse tight against heater.
Wires not shorted on high limit mounted above heater
electric bill paid.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 07, 2009 | Maytag PYE2300AY Electric Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
157 people viewed this question
Top Dryers Experts
