Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
The fuel lines on the filter are rotten..the filter just fell out of the tank..do you have to buy a new tank to get the right filter set up??
    President:
  • 1,776 Answers
Just take the old filter with you to about any place that sells lawn equipment (WalMart, Tractor Supply, Ace Hardware, etc) and get a replacement filter. Most of these retailers carry replacement filters for trimmers/blowers. The filter should just stick in the end of the fuel line inside the tank.. Take the old one for comparison purposes. Hope this helped and best wishes.
Posted on Sep 24, 2009
Homelite leaf blower fuel tank pickup fell off
There should be something going into the tank, a plastic elbow or connector, that will connect the fuel line from the carb to the pick up in the tank. Generally what I do is remove what ever goes into the tank and get a piece of fuel line slightly bigger than the hole and insert the fuel line directly from the carb into the tank. You have to be sure the hose is really tight so to create an air tight seal. Pull the new hose out of the tank through the fuel fill and insert the new fuel filter, push the hose back in making sure it is on the bottom of the tank but has room to move around
Jan 22, 2013 | Homelite 308675004 Fuel Tank With Cap...
My weed eater's fuel lines are busted, do i need to get the whole tank assembly, it looks like their is a filter or float or some sort on the end of the line insisde the tank?
No, you don't need a new tank. You are right about the filter inside the tank.It will make it very easy for you if you can buy the new lines with a new filter attached, but if not, just buy the fuel line.
Jul 06, 2011 | Craftsman 25cc Gas Line Trimmer
My fuel lines became rotten and i'm not sure how to reconnect the in-tank fuel lines and filter
A bit more time consuming and requires patience more than skill on this task.
First, only take off 1 of the fuel lines at a time. That way you can make sure you put the right hose on the right fitting.
Let's start with the line with the filter. Take the line off the carburetor. Cut a bit of it and go to a mower repair shop to get your new fuel line. Get about 2 feet. That's about double what you need, but will probably waste some in the process. When you get the new line, cut a sharp point at 1 end. Get a needle nose pliers and reach into your fuel tank and pull out the filter and the rest of the fuel line. Get a fairly fine wire, wrap it around the pointed end of the new fuel line. Snake the wire into the tank and out the small hole. This will help you pull the new hose into the tank and out the hole. This might take a bit of time. When you get the new hose out, square off the end and push it on the carb fitting. Cut the hose where it enters the tank and slip your fuel filter on and drop into the tank. 1 down and 1 to go.
Host #2 can be put into the tank the same as #1, or you can try to push it in from the top. May work with a little lubrication. Hook #2 up to the carb.
This should get you up and running.
Oct 25, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite ST-185 (15039A). Route new fuel line.
If you look closely there should be 2 holes in the fuel tank, also if you look inside the fuel tank there should be some remaining pieces of the fuel line and a fuel filter. If this has been sitting for any length of time you will also want to replace the fuel filter.
Now comes the fun... or a challenge
To start with you will need 2 sizes of fuel line ( go to a small engine repair shop) while you are replacing things you may want to buy a new primer bulb also.
to insert the fuel lines into the tank you will have to cut a tapered tail about 2 " long so that you can grab the fuel line with a needle nose and pull them through and out of the tank so that you can trim off the tapered tails. On one install the fuel filter and stick back into the tank, on the other trim the tapered tail off and pull the line back into the tank but leave about 1" sticking through the tank.
Now hook up you fuel lines to the carb and/ or primer bulb
Fill tank half full with fuel ... now test the installation if it doesn't pump fuel but instead you can hear it blow bubbles in the tank it is simple just reverse your lines on the carb / primer bulb
Retest if it works like it should you are ready to attempt to start it... good luck
Sep 08, 2009 | Homelite Garden
Fuel lines inside of tank fell off
This is the typical fuel line routing2.gif on many models: One line ( the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 05, 2009 | Craftsman 25cc Gas Line Trimmer
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
23cc weedeater fuel line to filter in tank is rotten
1st get new line. find where it goes on carb. pull the line out of the tank .cut a pc. of new line longer then what you need ,cut the end of the tubing with dia.pliers at a long angle then push it into the tank untill you can fish it out hook it back to the filter pull the extra tubing back towards the carb. leaving the filter at the bottom of the tank
Jun 18, 2009 | Craftsman 25cc Gas Line Trimmer
Gas lines rotten replaced new but not sure in right place
The short one goes to the primer bulb and the long one, with the filter in the tank, goes to the carb.
Jim
Jun 05, 2009 | Ryobi Garden
Mcculloch gas chain saw / 3200 changed fuel hoses due to rot
The line from carb goes to bulb inlet, the bulb outlet goes to tank. Line with filter goes to carb inlet.
Mar 21, 2009 | McCulloch 26cc Gas Blower Mcb3208
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
298 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
