Question about Troy Bilt 5.5hp Self Propelled Mower
No tnesion presnet when I squeeze the handle.
No tension present when I squeeze the handle to initiate the self propel motor. cable is loose - where does cable attach in front? It is not connected to anything under the drive cover when I looked uner it and I cna't tell where to attach it
  • 62 Answers
REPLACE THE CABLE
Posted on Sep 25, 2009
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
HOW TO REPLACE DRIVE CABLE ON TROY BUILT 12A466MO11
Parts Finder Search Results
46 732-1043 Belt Tension Spring open the above link above and zoom in as much as possible on the diagram. Find part #46, which is the belt tension spring. Now locate it on your mower and look at the whole mechanism , where the pulley is. Check to see if it engages when the cable is put put into drive. Order new parts as needed.
May 20, 2014 | Troy Bilt 5.5hp Self Propelled Mower
My self propell lawn mower stop propell
the cable needs tension to engage the belt tensioner
Sep 23, 2012 | Garden
Hi, I have a JS63C self propelled push mower that is having trouble with the self proppelled device. At the first speed 1 you can feel some self propell. However, if you advance to speed 2 or speed 3 you...
Hi Jerry. Sounds like your transmission cable needs to be adjusted. Since 1st gear is easiest for it to move in, you probably have little pressure on the clutch. Take the cover off the back of the mower (Torx T25 or T30 can't remember at the moment.) The spring on the cable should be measured when relaxed (handle not being held) then when you squeeze the S/P handle, it should stretch the spring 10mm. A friend or a clamp will make holding the handle and measuring more simple. Adjust the bracket the cable clips into in front of the tranny to obtain the desired 10mm, and you should be under power again.
Jun 03, 2011 | John Deere Garden
Limited self propell
The self propel cable needs to be adjusted. This can be done with a 7/16 wrench. loosen the nut that holds the self propel cable in place. You may need to pry this open with a screwdriver. Don't overdo it or you could break the plastic. Once the cable is loose pull it toward the mower deck, once the slack is out of the cable press the self propel handle in about a half of an inch. This should be close to what it was from the factory. Then re tighten the nut. And check the self propel to make sure it is engaging properly. If you hear a grinding noise when trying to engage the transmission then you will need a new transmission. Depending on if it is a front or rear self propel the part alone is either $60-$75 retail. Most repair shops will charge an hour to do this repair. I hope this answers your question.
Mar 24, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Hoover wind tunnel won't self propel
There are really two reasons why the self-propelled wouldn't work. It could either be the belts on the vacuum cleaner are stretched or broken. The belts on this model control both the self-propelled transmission, as well as the brush roller. Here's a video that shows you how to inspect the roller brush and belts to make sure that they are installed properly and working. Try this repair first, as this is the easier one to fix.
The other problem if the belts are installed properly that would cause the self-propelled wouldn't work would be the self-propelled actuator arm. There is a cable that starts at the handle of the vacuum, and runs all the way down to the floor head of the vacuum that controls the transmission. As you pull backwards on the handle of the vacuum, the cable pulls this actuator arm backwards, which then turns the wheels backwards, and when you push forward it turns the wheels forward.
The problem with the way it's designed however, is that if you pick up the vacuum cleaner by the handle of the machine rather then using the carrying handle on the back of the vacuum, it causes too much tension on the actuator arm, and will cause the cable to rip right out of the arm.
This is a VERY common problem on this model. To check and see if this part is broken on your vacuum, step on the handle release pedal so that the handle is in the vacuuming position, push the pedal a second time so the machine lays flat on the floor.
Now if you look right behind the height adjustment switch, and the rug / floor switch where the floor part meets the upright part, you should see a cable that connects into the actuator arm. Pull up and down on the handle and look for movement. Is the cable loose with only a nut attached to it, or is it resting in the actuator arm?
Here's a very helpful link that shows you exactly how to replace the actuator arm:
How to Replace the Actuator Arm on Hoover Self-Propelled Windtunnel
If this didn't help you, and the problem is still happening, please just use the add a comment form here on Fixya and let me know that you're still having problems. I'd be honored to go through and do some more advanced diagnosing with you.
I hope this we helpful to you. If you did find this helpful, please be so kind and leave feedback for me. This is why repair professionals like myself continue to come back and give free repair advice, to get the recognition of a job well done.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 17, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
My toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Aug 08, 2009 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
410 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
