The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken:
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive.
This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Yes, but further help depends on what country you live in. Go Here and find your country. Where to buy is at the bottom of the page
