Question about Sony VAIO PCV-RS422X PC Desktop
My pc is making a click sounf and the and the light underneath the power button is blinking. A screen does not shouw on my screen
  • 3,153 Answers
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE
Posted on Sep 24, 2009
  • Project NOMAD
    Project NOMAD Sep 24, 2009
    Other causes could be a dead or dying power supply or a clogged up fan
    cleaning out the inside of your computer is a cheap way to see if it this.
    Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
    I would suggest getting a can of compressed air made for computers
    take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
    While you are in there just check that the CPU cooler itself is not loose
    If it is it will have to be re-seated.
    If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem the have to be cleaned and new thermal grease put on
    I think this may be your problem before you buy a new CPU make sure you check the cooler assembly and make sure you use new thermal grease ($2-5)
    DON'T remove the CPU just the fan/cooler assembly.
    You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
    DON'T pour the alcohol over the CPU
    Now apply some new thermal grease (most computer shops have it)
    Be careful about how much you put on
    Here are
    some basic instructions
    Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
    If everything went to plan you should now be back in business
  • 69 Answers
You have a failure in the computer
Light flashes 4 blink and 1 long blink i press the power button i hear a click it starts flashing red and the screen is dark
The click is probably a short of some kind, possibly in the power control board. Please add the make and model of the tv and repost the query
Jun 08, 2016 | Televison & Video
Hp mini laptop screen problems!
You may have to get a new screen if the crystals or caps are broken inside. Do check all your wiring and connections first. I can help with that.
Jun 10, 2012 | HP Mini 1000 Netbook
PC 4 bleats but will not boot up.
What make and model is your computer? It's probably the memory or video card that's causing it not to boot.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 05, 2012 | Computers & Internet
Lx6810 blinking power light
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Pressand Hold the power button for 30 seconds. After 30 seconds plug the powercord back in and hit the power button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light come on but not enough power to make the fan turn on or hard drive spin.
May 10, 2012 | Gateway LX6810-01 PC Desktop
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Monitor gets a square marked loicked in the middle of the screen. modem blinks on/off. help!
To change your screen saver, right click on the clear area of your desktop and and click on properties. Then, at the top info bar, click on the screen saver button and select a screen saver from the list that you want.
For the blinking light on your modem, it is supposed to blink, and if you want to, you could move it a certain way where you won't see it blinking.
Oct 17, 2008 | E-Machines eMachines Desktop PC
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Sony VAIO PCV-RS422X PC Desktop Logo
48 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
