Question about Maytag Atlantis MAV6000 Top Load Washer
My maytag washing machine is not working not leting out and it is not making any sound.
Washing not working not leting water out . the water is just sitting there.
    Scholar:
  • 90 Answers
Does it spin? If nothing is happening the control is probably bad.. If it spins, see if any water goes out the drain hose. lower the end of the hose into a bucket setting lower than the level of the water inside the tank. If it will not drain there is a plug in the drain lines...
Posted on Feb 03, 2008
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Going through wash cycle but not spinning
my indesit starts to wash then comes up with 3 falshing lights and just keeps leting in water if i put the machine on with nothing in it it goes the wash until it gets to spin then starts to spin and agian starts letting in water
Mar 26, 2010 | Indesit W 123 Front Load Washer
The machine is not filling and all the display lights are flashing.Thankyou.
It sounds like ether youre plumbing is not leting water down the pipe or the valves have gone inside youre washing machine try filling the washing machine up via the powder dispensing draw with the front door of the macine shut and the macine off when the machine is full of water swich it to the program you want and see if it works if it does then its the valves in the machine burt before you do that unhook the filling hose from the wall and see if water is coming out if not its youre plumbing
Nov 27, 2009 | Office Equipment & Supplies
Maytag PAV2300AWW Washer makes grinding sound when agitating
Sounds like it is the bearing on the water pump. Take off back plate and replace and remove 3 screws and two hoses (the one hose is a waste line so make sure you have a bucket to empty our waste water) after removing these remove belt on bottom of pump.
Sep 29, 2009 | Maytag Performa PAV3200
WATER TURNED OFF AT ROAD TO REPAIR PROBLEM NOW GETTING F20 WHEN TRYING TO WASH LAUNDRY.
check and make sure you have water going to your washer you might have got some junk in the line and is not leting water in
Jun 26, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Aug 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
47 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
