Question about RIM BlackBerry Storm 9530 Smartphone
Blackberry 9530 storm every time i get a call or make a call I have to push the blackberry button to activate the handset. What's up with this phone.
Free MEP code for blackberry storm 9530
Are you asking a MEP code for unlocking your Blackberry 9530? If so you can get the accurate unlock code from www.unlocking4u.com/blackberry-9530/rs6wp9/ at affordable cost. Here are the steps for unlocking a Blackberry 9530:
- Switch ON your Blackberry 9530 phone with Not Accepted SIM Card.
2 - Click on Turn All Connections Off.
3 - Press Back button to go Back one Step.
4 - Go to Options.
5 - Select SIM Card.
6 - Press the Menu Key and select Show Keyboard.
7 - Tilt the phone in Horizontal Position so that the Keyboard is displayed in the Landscape Mode.
8 - Type MEPD (letters will not appear on-screen but a menu will pop up).
9 - Type MEP2 (user will be prompted to enter MEP code).
10 - Enter the unlock code.
11 - The Blackberry 9530 phone would then display the message 'Code Accepted' and unlocked successfully!
12 - Go back to the Home Screen. Press the Menu Button and click on Manage Connections.
13 - Click on Turn All Connections On.
14 - The phone will now reboot and 'Activation Required' will no longer be displayed
Sep 11, 2012 | RIM BlackBerry Storm 9530 Smartphone
Am using verizon 9530 unlocked. phone is working, the backlight is active on buttons...!! the screen is not active.. i could answer / receive calls.. can hear the notifications of receiving emails /...
When you get your blackberry screen blackout? After your blackberry 9530 unlocked or a few days after you unlocked your phone? Did you get my point? If you get that blackout screen after blackberry unlocked process try to reset your phone to default factory setting and if still not working try to reinstall your blackberry os, but if you get that blackout screen a few days after you unlock your phone looks like your screen already broken and you need to replace it in your nearest local mobile repair shop.
Jun 11, 2011 | RIM BlackBerry Storm 9530 Smartphone
I need MEP Code to unlock Verizon blackberry storm 9530 phone to use on Tmobile Network. Tmobile told me to call Verizon to get the MEP code and they will not give me the code. Can you help me?...
As far as i know unlocking by codes is the simple and safe way.You will need the unique MEP Code for your Blackberry storm 9530 and to get it you can use a website with service for Blackberry unlocking .so you can use a website to Unlock your Blackberry storm 9530 online instantly - OR local mobile shop .they are mostly using cables to unlock it and the price is higher then on unlocking websites but the result is the same: SIM free Blackberry.
Mar 24, 2011 | RIM BlackBerry Storm 9530 Smartphone
How to get free mep code for blackberry storm 9530
Hello
you can get Blackberry Storm 9530 MEP unlock code from this Blackberry MEP unlock code provider to use your Blackberry with any GSM SIM card around the globe,
i hope this provider will help you for unlocking Blackberry device,
thanks
Oct 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
I have blackberry storm 9530, i need mep code i one help me please
There are two methods for unlocking Blackberry storm 9530 by MEP number and by IMEI#.
The simplest method for unlocking by IMEI#.
You can find your Blackberry storm 9530
IMEI number by follow one of these steps.
1.By Pressing *#06# into the phone.
2.On your Blackberry cell phone, go to Options-->Status.
3.put the battery out,there should be a white sticker it will show your Blackberry IMEI #.
This Blackberry Unlocking codes provider provides unlock code for Blackberry storm 9530.
Hope this helps.
Jun 28, 2010 | RIM BlackBerry Storm 9530 Smartphone
Hi i am from india and i have just purchased blackberry verizon 9530 and now i want it to work on reliance network in india how do i do that....the device is already unlocked and is able to work on gsm...
if it is unlocked then you can try it by inserting the sim in your handset. Please contact reliance customer care and ask them to activate blackberry services on your phone. If you are not able to use it then contact blackberry service center they will help regarding this.
May 20, 2010 | RIM BlackBerry Storm 9530 Smartphone
How do i get a mep code to unlock my blackberry storm 9530 for free even if i do have a plan with them
YOU HAVE TO GO TO WI FI AND YOU HAVE TO SIGN UP AND THAN SIGN IN BEGAIN FIXING YOUR PROBLEMS .
Mar 29, 2010 | RIM BlackBerry Storm 9530 Smartphone
Hello, have black berry storm 9530. it is unlocked, trying to use it out of country, but is in sos mode, please help
1) Please check with service provider,if the international services are active on your sim,
2) Please swap the sim in other phone and chek the sim is working fine
3) Please check your blackberry handset with other sim if it is working fine.
Nov 01, 2009 | RIM BlackBerry Storm 9530 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
170 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
