Question about RCA DRC8052N DVD Recorder
I have a rca dcr8052,and when hooked up with s-video cable i cann not get sound.
  • 146 Answers
S-video only passes the VIDEO - you will need to make sure you also use the WHITE and RED connectors which are stereo L and R channels - for your audio input and for your audio output as well. Make sure you plugged your audio inputs in the right line input. Example, if you are plugging S-video in LINE 1, make sure your red and white cables are plugged in LINE 1 audio input !
Posted on Sep 24, 2009
Norcent DP 1800 dvd player has video, but no sound output with rca hook ups. No remote what do I do.
I'm thinking the audio cables are not connected properly because you do have video. Do you have an owner's manual for hooking up the audio? You may be able to find a manual online?
Dec 22, 2017 | RCA Televison & Video
I have a RCA RP8065 A 5cd changer it only has audio cables and power cord how do I hook to tv
Hook up the Audio cables to any input that accepts them, you will have sound but no picture, then use the remote to select that input you used.
Mar 14, 2017 | RCA Televison & Video
I can't get it hooked up.
First connect the RCA cable to DVD player as seen below, At the left side there are 2 yellow sockets, any of them can be used for video, and White/Red for sound, On your TV Side follow the same colors and use Video Input group of RCA sockets.
Good Luck
Sep 16, 2012 | Apex Digital AD-1500 DVD Player
No sound
the s video is only for video, you must also have a red and white rca cable connected also
Feb 23, 2012 | Televison & Video
Which cable should be hook up to tv. Trying to hook up DVD player. I have cable with Red, white, yellow.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Jun 03, 2011 | JVC C-13920 TV
I have a RCA HD52W59 but i cant find a hdmi. What do i do?
Used a S-Video cable for video hook up and a RCA component Red,White cable for a audio output hook up.Or used a all in one RCA component cable Yellow,Red,White for a hook up as a simular hook up for traditional VCR hook up before.
May 28, 2011 | RCA HD52W59 HDTV Projection Television
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
No HDMI output with Panasonic SC-PT950
Change the video out settings from your system
Dec 10, 2008 | Sony DAV-S400 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
No picture
Tvs usualy have a few ways to hook them up. One is a coax cable this is the silver one in the back that you screw in a cable. The second are RCA cables these are the ones that are yellow, red and white. Yellow is always the video and white and red are for audio. If your using the coax cable your tv needs to be on channel 3 or 4 you may have to force the tv to go to that channel by pushing 03 on the remote. If you are using the Rca cables then you need to change the tv to "video 1" or "video 2" this changes the tv from tunner mode to aux input mode. Most DVD players dont have a coax out so you have to use the rca plugs. Some tvs have the rca plugs on the front (video 2) and the back (video 1) or line in. Some tvs have line out also so you need to figure out wich way you have it hooked up. Do a search for the model of your tv and it should show a diagram on how to hook it up.
Apr 07, 2006 | Emerson EWD2003 DVD Player/VCR
RCA DRC8052N DVD Recorder Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
