Question about Proscan 26LB30QD 26 in. LCD HDTV
Tv on mount now no picture no sound
Protron tv
    Novelist:
  • 128 Answers
It could be many things, so these are only guesses:
1) power cord loose, power connector damaged
2) Incorrect screws used for mount (too long) have damaged internals of the TV.
3) vibration of installing mount has somehow caused an internal component to come loose.
Posted on Oct 07, 2009
My protron tv pltv-32c has no picture but has sound, if you change channels the picture will flash on for about 1 second
Hi.
If there is sound but no picture, screen is completely dark and the picture is occasionally flashing, then the fault is likely a faulty inverter. In some case a faulty controller board or a defective PSU can cause the same problem.
I summarized the problem here:My LCD TV has sound but no picture.
I posted general procedure to test inverter, PSU and controller board on LCD here : How to test an LCD TV or monitor PSU and inverter.
If screen is not dark, but has blacklight or noise things are different. In that case check connection cables first. Parts that may be defective are main controller board, terminal circuit and tuner board.
Protron parts are available using the link below. Ensure that parts are compatible with your model before purchasing.
ShopJimmy - Protron Parts.
Regards.
May 15, 2010 | Televison & Video
I have a PROTRON Flat screen tv SRS BBEDigital
have a PROTRON Flat screen tv SRS BBEDigital that I will like to install on the wall. I do not see any holds in back of the TV for a mounting bracket. How do I mounted on the wall?
Jan 31, 2010 | Protron PLTV-32 Television
Can thris protron tv be mounted on a wall?
it can be mounted, they sell a universal hanging kit, you will see 4 holes in the back of the tv, thats where you put the screws for the mount
Jan 11, 2009 | Protron PLTV-4250 42 in. LCD Television
Want to wall mount tv but don't don't were to bolt.
I have my 32" Protron mounted on my wall. There are six holes on the back of the set that you attach the mount. I cant find any links to pictures but it should be pretty straight forward. You should be able to use any generic LCD wall mount, just make sure it can hold an 32" since I made the mistake thinking all wall mounts were the same. I purchased mine at Best Buy but you should be able to find a mount anywhere. You will need to fasten the mount onto the studs in your wall. Drywall by itself will not be sufficient and cannot support the weight of the TV.
The wall mount should come with everything you need, e.g., screws, brackets, etc., with the exception of the tools. FYI... it's not going to be an easy job so be patient and take your time. It's probably going to take the good portion of a day. Also, as for the holes on the back, just be careful when performing the final mount to make sure it doesn't fall. It would be wise to have someone help you.
Nov 25, 2008 | Protron PLTV-32 Television
No sound on protron lcd tv
Go to the set up menu and select audio. check that the speakers are ON.. Then make sure that stereo is selected. If the set is set to alt sound there wont be any sound.
Jun 13, 2008 | Protron PLTV-37 37 in. LCD Television
Help With My Protron Flat Screen TV
I rebooted the television. Turned it off, unplugged it and disconnected the cabletelevision. I left it that way for about 10 minutes and replugged it all back in and turned it on. It works great now!
Jun 10, 2008 | Protron PLTV-32 Television
PROTRON TV HAS NO PICTURE ANYMORE
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
Nov 24, 2007 | Protron PLTV-32 Television
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Nov 04, 2007 | Protron PLTV-32 Television
Hdtv problems-protron tv
are you using the cable company's remote on this tv?
Aug 21, 2007 | Protron PLTV-32 Television
PROTRON - PD-007
make sure you connected your plugs to the video you have on your tv( video1, video 2) unless you have to have it on ch 3 or 4
Jul 17, 2007 | Protron PD-800 DVD Player
Proscan 26LB30QD 26 in. LCD HDTV Logo
94 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
