Question about Maytag Neptune MDE5500AY Electric Dryer
How to replace the drum rollers on a Neptune MDE5500AY dryer
  • Maytag Master
  • 8,404 Answers
Generic comment:
Normally, these wheels are held on by a spring clip.
Are your wheels shot are are you having a bearing trouble?
I hope this helps you.
a
Posted on Sep 24, 2009
Neptune dryer makes noise
Check the blower to make sure it is properly secured on the motor shaft. Also check all of the bearings: motor, tensioner pulley and drum support rollers or drum bearings. You may have to disengage the belt to check the motor and tensioner.
Oct 06, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Started squeaking a couple weeks ago now it is a loud growl rumbling.
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Here is a link to the part you need.
Jan 02, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Dryer squeaks when it runs
Do Not Use oil.
Replace the drum rollers,clean the belt tension roller and the front drum glides.
Repeat...No Oil.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My neptune dryer squeals when i turn it on ,i replaced the belt but noise is still there until it warms up,what is wrong
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Also check you drum belt for condition, sometimes they will wear and squeal as it is running till the belt gets hot.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Dec 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Has a loud squeeking noise
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Neptune gas dryer rattles sporadically when running.
do you fell it rattleing alot? Its can be the rollers are very worn and need to be replaced or the center of the rollers need to be greased up. hope this helps...
Jul 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
DRUM/TUMBLER ISSUE
look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Mar 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
306 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
