Question about Hotpoint HSS25GFP Side by Side Refrigerator
Bottom cools and top cools but dose not freeze . Do not heart fan when frezzer is opened.
  • 146 Answers
You do not hear the fan ? your evaporator fan is not working - shut off everything and remove freezer panel look for any excess ice or frust blocking the fan - if everything is clear try spinning the fan blades with your hands, is there any resistence or it spins freely ? Put back cover and turn it on - if fan fails to spin then you have to get it serviced and change the evap fan motor assembly or check the control board.
your unit won't cool if the fan is not working or working erratically.
Posted on Sep 24, 2009
Testimonial: "Thanks I will check suggested causes"
  • Hotpoint Master
  • 1,606 Answers
If you open the freezer door , and press in the light switch , and not hear the fan motor , then the most common cause , is a bad main control board . Pt # WR55X10656 . This is the control board located on the back of the refrig , behind an 8"X10" panel . There is a resistor that burns on the board , causing the fan to stop . This board , controls every operation of the refrig .
Testimonial: "Thanks I will check suggested cause."
Bottom of freezer freezing bottom of frig cooling top of freezer and top of frig not cooling or freezing
I'm thinking you have a Bad fan. Not circulating air? You should hear the fan running when you open the door.
Feb 13, 2018 | Refrigerators
Frezzer is freezing properly but refridgorator is not cooling
I had the same problem a month ago on my Hotpoint side/side. The fan was not operating which allows the blowing of cool air into the fridge portion. Open your freezer and listen for the blower. You may just need to hit it gently to get it going. Also, if your freezer needs to be defrosted that impacts the blowing capability.
I had to call a repair person to replace the board where the fan was located since it went bad. I hope this helps you.
Jan 23, 2011 | Refrigerators
Refrigerator is not cooling on top part of freg side only the bottom part is cool. The frezzer is working fine.
You may have a circulation problem. Check the the vent, if it's a side by side, inside refrigerator, on top towards back and feel for airflow. If there is no airflow from freezer into the refrigerator then you may have a evaporator fan that went bad or else you have a defrost problem - evaporator is clogged with frost which inhibits air flow.
Nov 24, 2010 | Refrigerators
Have a mtf2193arw fan in frezzer is working; refrig is not cooling the fan did fall of the spinner and was put back on; ice maker is slow; back and underneath have been cleaned; maytag top freezer unit
Unless the plastic opening is cracked in cente, try placing some adhesive on opening and slide it back on the evaporator motor shaft. If needed the part number for fan is 63002045
Sea Breeze
Jan 26, 2010 | Refrigerators
My refrigerator haier hte21waaww doesn't work, just the frezzer,
1...Check the fan that pushes the air from the freezer to the refrigerator it could be defective, if it is it will cause this type of problem. 2...Check your thermostat and make sure it is on the colder setting. I hope this helped you, Please rate me...Thanks
Jan 05, 2010 | Haier HTE21WAAWW Top Freezer Refrigerator
Unit has stopped cooling and freezing also making gurgling noise
it sounds like the frezzer fan stoped and what your hereing is the freon coming in
Apr 17, 2009 | Refrigerators
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
Kenmore 596.72913200 Refrigerator is Warm,and freezer is not freezing
If your evaporator is still frozen over after turning the screw twice you problem is in the heater circuit. Defrost heater could be open or the defrost thermostat.
Jun 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
New Sanyo Fridge not working
I have the sam eproblem but my freezer is very cool, but the fridge wont get cold, it is just chilled, my food still goes bad and the water and soda is room tem..this doesnt make sense!
Nov 25, 2007 | Sanyo SR-1030W Top Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
147 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
