Question about Quad Disc Brake Rotor 160mm Bicycle Bike
I just changed the brakes on my quad and when i hit the brake they dont lock up they slowly stop
  • 67 Answers
If its hydraulic youll need to bleed the calipers and or lines. You may have an air bubble or low fluid. If its old cable style, theres a cable with a nut near the ends that screws out and tightens the cable by elongating the cable distance thus adjusting it.
Posted on Sep 24, 2009
I have a 1998 Monte Carlos. I had to slam on the brakes and.now the ABS light and brake lights are on. What could it be. They were fine before I had to slam on my brakes to avoid a car in front if me.
You have a brake fluid pump on board that over rides high pressure to keep the wheels from locking up by openning a bypass valve. If you can lock up the wheels by hitting the brakes hard the valve is stuck :( very costly. If they dont lock its electrical if they do you just wont have ABS. This is something that was passed on to me so i drove without ABS car stopped fine.
Aug 25, 2012 | Cars & Trucks
96 front passenger side brake line at booster into spliter witch one is front right brake line
1996 on the master cyclinder the 2 connections are the one in the back part of the master cylinder is the primary circuit that is the front brake section and the one farthest from the back of the rear of the master cylinder is the secondary which will go to the rear of the brakes. Now this is going to look confusing as it attaches to a combination valve,why it is because you have a diaginal split this is design for brake hydraulic failure.Now when you get everything installed make sure you bleed the system. make sure your pedal is firm if it stop funny and the rear lock up reverse it the front is where you want all braking power the rear only slowly engages and not that quick it is designed that way so you stop in a straight position the rear brake keep you straight they dont realy stop the vehicle.
Apr 23, 2011 | 1997 Dodge Intrepid
1998 ford escort se hand brake need adjusting. doesn't hold.
Try to adjust the rear brakes tighter at the shoes, if you have drum brakes. May require taking the drum off and adjusting the adjuster. Or, adjusting it from the backing plate access hole if there is one.
Be sure to check the cables to make sure they are not broken anywhere between the hand brake lever and the back brakes.
Good luck on this repair.
ADJUSTMENT
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the brake drum.
  4. Using a brake adjusting gauge, measure the inside diameter of the brake
    drum.
  5. Compare the brake drum measurement to the brake shoes.
  6. Adjust the brake shoes by inserting a brake adjustment tool into the knurled
    quadrant of the rear quad operating lever and adjust the shoes to the same
    measurement as the brake drum.
  7. Install the brake drum.
  8. Install the wheel and tire assembly.
  9. Lower the vehicle.
  10. Check the brake system operation by making several stops while driving
    slowly forward.
Nov 02, 2010 | 1998 Ford Escort
2004 Dodge Dakota Quad Cab: The brake lights wont light up at the rear of the truck and the Center High Mounted Stop Light wont turn off.
Im having the same issue on my 04 Quad Cab Dakota. Changed out the brake light switch but still no brake lights. You have any luck ?
Oct 09, 2010 | 2000 Chrysler Concorde
Dear sirs,I have a Ford F150 4x4 1998,if I have to do a panic stop, the brakes dont stop inmediately the car,I change the brake pads,but is the same,can you help me? Bernardino
if your pards and rotors are fine, then maybe you need to bleed your brakes and/or to replace the brake fluid. how dirty it is? how is the level of it?
Apr 27, 2010 | 1998 Ford F150 Regular Cab
Brakes sound like airbrakes and dont stop right 2001 blazor
You may have damaged your Master Cylinder or have a leaky Caliper Piston.
Jul 13, 2009 | 2001 GMC Savana
Brakes locked up ran through stop sign 04 santa fe
it sounds to mee like the brake power booster or abs is acting up.if you dont feel safe driving it use it as a trade in for another vehicle that you feel more comfortable with
Jan 27, 2009 | 2007 Hyundai Santa Fe Limited
Slow drag starts, stalling and surging when at a stop
you could have a brake booster issue. you can do a simple test on another car by leaving the engine off and press the brake repeatedly 3 or four times will use up the vacuum in the brake booster. Once you have done this does it feel like the brake pedal in your van?
Jan 16, 2009 | 2000 Mazda MPV
Open Questions:
Quad Disc Brake Rotor 160mm Bicycle Bike Logo
114 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
