Question about HP Photosmart C3180 All-In-One InkJet Printer
I've forgotten how to change the ink cartridges.
I have a HP3180 printer All-in-One and I've forgotten how to change the ink cartridges. Could you please remind me of the steps. Thanks.
  • 615 Answers
Open the front door and the printer will move back and forward and then it will stop and you will see that the ink cartridges facing you pull down the back first and clean the inside then pull the color one and clean the inside then take out the cover from the new ones and make sure that the vent holes are clear and place them back starting by the black first and make sure that the ink set in the houseing good and you hear a click then do same with the other one...close the door and run your alignmnets and you are good as new...let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
    President:
  • 2,185 Answers
Here are the instructions. Hope this helps.
How do i change the ink cartridge
    • Make sure the printer is plugged in and turned on.
    • Grasp the front top of the printer. This is the Scanning Unit Cover.
    • Lift the Scanning Unit Cover gently until you hear a click. The cover will remain open by itself.
    • Wait while the cartridge holder moves from the left to the center of the printer. The ink cartridges are located in the cartridge holder.
2. Then from there you just need to remove each individual ink cartridge and replace it with your newly purchased cartridges. Be sure to replace each one in it's appropriate location!
Jul 24, 2011 | Canon Pixma MP480 All-In-One InkJet...
I just replaced my ink cartridge and now it's printing blank pages. I've unplugged & restarted the printer however the problem still exists. The printer says there is an "alignment...
Run a few "print-head-cleaning" cycles, to get the black ink flowing through the ink-jets inside the print-head.
Some printers REQUIRE an "alignment" step every time you change the ink-cartridges.
It only takes a few minutes, and it prints one or two pages of paper.
Jun 20, 2011 | Dell 924 All-in-One InkJet Printer
How do I know how much ink is left in my c3135 printer
Welcome to Fixya.
Here's how to determine the ink levels for your inkjet printer :
HPC3135 Ink Level check
Please see my additional reminders :
  • If the printing quality diminishes, it's a good time to check your ink levels.
  • Change your cartridge often for good printing quality.
  • If you refill the cartridge, the ink level indicator may not be accurate.
  • Don't wait until the last minute to change your cartridge.
Thanks for using Fixya.
Jun 05, 2011 | HP Photosmart C3135 All-In-One InkJet...
Please tell me how to change my ink cartridge
Please refer to this article How to Change the Cartridges on Lexmark Inkjet and All-In-One Printers. Note: The printer shown in the article may not be the same model as your Lexmark printer, however, the steps are the same.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
I hope this information has been helpful. Thanks.
Dec 14, 2010 | Lexmark C533DN InkJet Printer
How to load a MP130 cartridge?
  • 1 Turn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
  • 2 Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
  • 3 Pull out the used ink cartridge by pulling straight up from the print head,
  • 4, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
  • 5 Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
  • Nov 13, 2010 | Canon PIXMA MP130 All-In-One InkJet...
    HOW DO I CHANGE MY INK CARTRIDGE?
    1. Step 1 Purchase an ink cartridge made specifically for your printer.
    2. Step 2 Turn on your printer and raise the lid or press the cartridge changing button.
    3. Step 3 Wait for the cartridge carrier to slide out.
    4. Step 4 Put your finger behind the ridge on the top front of the old cartridge and pull it toward you to remove. If you have an Epsonmag-glass_10x10.gif printer, lift the cartridge holder lid, and the cartridge will pop up for removal.
    5. Step 5 Carefully remove the tape from the ink opening on the bottom of new cartridge.
    6. Step 6 Insert the new cartridge into the cartridge carrier. Make sure the new cartridge is oriented the same way that the old cartridge had been.
    7. Step 7 Feel and hear the cartridge click into position. On some models, arrows will indicate the cartridge is correctly positioned.
    8. Step 8 If you have an Epson printermag-glass_10x10.gif, close the cartridge holder lid and press the cleaning button to charge the cartridge.
    9. Step 9 Close printer cover.
    Thanks
    Apr 24, 2010 | Epson RX620 All-In-One InkJet Photo...
    My dell 924 printer shows right cartridge incorrect and I just had both cartridges refilled what is wrong?
    I purchased remanufactured ink cartridges through amazon.com. I got 4 for the price of 1 through Dell. After installing the first cartridge, it printed for a few days and then I got the same message "left cartridge incorrect". Unfortunately, I did not read the piece of paper that came with my cartridge that says "STOP" read this before you install the cartridge.
    I had to throw out the cartridge that I had just installed and put in a new one and follow these steps:
    1. If you recieve a pop-up message indicating that the cartridge has been depleted or a low ink level warning, please disregard.
    2. Check "Don't display this dialog again" and click "ok" or "continue printing" if necessary.
    3. In the printer status window, since you have already ordered ink, do not click the "order ink online" button. If you have the option, check "I have ordered my ink, please don't remind me again." If not, close the window and continue printing.
    I'm not sure why, but these instructions were vital to getting my remanufactured cartridges to work.
    I am posting this reply to hopefully help out the next person that has this problem. Unfortunately, I lost a perfectly good ink cartridge because I failed to read the instructions the first time. But the next one worked just fine when I followed the instructions. Good luck!
    Mar 09, 2010 | Dell 924 All-in-One InkJet Printer
    HOW DO I CHANGE INK IN AN EPSON SX200
    Hi
    Thanks for using FixYa. Turn the printer on. Now raise the lid of the cartridge cage and wait for the cartridge carrier to slide out. Lift the cartridge holder lid and remove the cartridge. Before installing the new Cartridge, remove the tape from the ink opening point on the bottom. Now insert the new cartridge into the cartridge case and close the cartridge holder lid. Close printer cover. After doing all the above steps, print a test page.
    Please do rate the solution and revert for further assistance.
    Thanks
    Rylee
    Sep 26, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    How to remove ink cartridge for hp 4150 printer?
    Hi there
    step #0
    Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
    Step #12Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer. Step #23Press the change cartridge button. It is at the top of the printer next to the power button. Step #34Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process. Step#45#4Recycle the empty inkjet cartridge or have it refilled at an ink refilling center. Step #56Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed. Step #67Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door. thanks Hamedo
    Nov 22, 2008 | Office Equipment & Supplies
    Brand New Printer
    Hi Teetle, No, it not normal to only get two pages per cartridge. I would try the following before contacting Epson tech support: -Remove the cartridges and clean the contacts on both the printer and cartridge. -Reinsert each cartridge making sure it is seated correctly. -Buy one black cartridge and install. It is possible that the cartridge is defective but since the magenta cartridge is showing low its unlikely. Tech support will want you to try it before they will replace the printer so you?re best off trying it now. If after trying this steps there is no change and if you?ve had it for less than 7 days I would talk to your retail store. Usually they will just trade your defective unit for one in stock. If you have had it longer contact Epson support and explain what it happening and what you?ve done. Make sure you mention you?ve bought a new Epson black cartridge with no change. Let us know if you have any other questions and please don?t forget to rate this post.
    Jan 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
    HP Photosmart C3180 All-In-One InkJet Printer Logo
    Seeker5211
    Seeker5211
