Question about Watches
Illinois pocket watch stem removal.
How do i remove the stem from a illinois pocket watch ser number 3448348
First you must say what type as there are differences depending on the mfg and model.Be the following basics apply.
1- Put the stem in the setting position (usually pulled out if stem set).
2 Them open cover to expose the movement. ( Screw off or snap open).
3- Remove the movement (Usually held in place with 2 screws at the outer edge.
4-Then if there is a screw in the part that holds the stem loosen that.
5- The stem can be held with a pair of pliers on the flat and the crown unscrewed. Be careful not to damage the square (FLATS), with the pliers. A rag or other safety measure should be taken.
6- then inside the stem hole, looking from the ouside the is an annular area around the stem that has a ferrule screwed into the case this has to be unscrewed and will bring out the stem and the ferrule.
This siounds complicated but the steps are more involved to write than they are to perform.
There are many variations to this process, and each type should be understood before proceeding.
Posted on Nov 24, 2009
How do I remove a pocket watch winding stem.
Posted on Dec 23, 2008
How can I set?
Shirley, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 17, 2016 | Watches
Changing the battery in a mickey mouse pocket watch
The first answer is a canned answer. Seen it before. Examine the edge of the pocket watch. Start at the stem and look for a slight gap where the back cover meets the case. It is usually at the stem side or hinge side. Once located take a strong sharp knife and carefully pry up the back cover. It should remove fairly easily. I have about 12 pocket watches and they all work the same way. Once open there may be a small screw or two holding the battery in place. You will need a precision screw driver set or a small screw driver for glasses.
682b943c-dbb9-4041-9abb-ed1a67105d52.jpg eff96e41-9266-48e7-9603-ac9206c667a0.jpg 03735b42-603a-41af-9aa7-4d445bd017dc.jpg
Jun 30, 2013 | Watches
I have an Illinois pocket watch with serial number 4449272, how much would this be worth
mcdevito75 here, An Illionis pocket watch doesa have collector value, how much is really up to the collector buying the watch, if the watch works well and the watch is clean , no rust or brassing it could bring up to $100.00 Check on ebay and see what they are going for, also check at your local jeweler see what they say.
Jun 14, 2010 | Watches
I have an Illinois pocket watch and I can't figure out how to open it to get the proper info to look it up. Can you help me plz?! Thank you
The back screws off.
Turn it Counter clockwise.
The numbers you need is the actual serial number off of the movement not the case.
We then can provide you the production information on your particular run of antique pocket watch.
Hope this tip helps.
Feb 19, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Have a waltham pocket watch in an illinois case enameled dial with a recessed seconds dial at bottom with a numeric 6. seconds on face also. can't find year or pic of this watch
If you go to the web site "", you will find information about Waltham watches and if you read the serial number off the movement (open the back and read it off the back plate), you may be able to find out the year of manufacture.
Feb 10, 2010 | Chase C6A Waltham Antique Ps Bartlett...
Can I find out from the serial number on an Illinois pocket watch if it is a dual time zone watch?
All the pocket watches that I have seen are designed so that the back hinges open (using your finger nails to open it).
All the watch information is usually inscribed on the mechanism.
Jan 15, 2010 | Watches
How to remove stem from scotty pocket watch
did you figuer it out because i am having the same problem, i don't want to take apart the balance just to change the and fix the face
Mar 20, 2009 | Watches
Watches Logo
997 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
