when wiring up 240v of power to compressor what is the black,red and white wire hooks up to when i hook up the red in black it run fine but when i add the white wire to the circuit it cuts out (its a speedair compressor)
blk/red are your two 120 volt lines the white is your neutral, if this is a 120/240volt combination motor make sure you change the wiring in the motor configuration to make it 240volt from 120volt
how do you charge powercraft 12v power stationlost manual,do all switchs have to be on or off. when...
(More)
how do you charge powercraft 12v power stationlost manual,do all switchs have to be on or off. when off no charge light is lit.
What is the standard single phase motor installed on a Marquip 15 air compressor. Speed/frame...
(More)
What is the standard single phase motor installed on a Marquip 15 air compressor. Speed/frame size/horsepower. I have a compressor but no motor or specs.
