Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn mower not running
I have a craftsman lt 1000 with a briggs 17.5 hp. that starts and will idle but when i try to throttle up it just starts to backfire alot, it wont die it just backfires, i have adjusted the valves and i took the bolt out of the flywheel and the key way is in good shape and doesnt look like it has been knocked out of time at all. I dont know what else to look at, any suggestions. thanks
    Top Expert:
  • Craftsman Master
  • 13,640 Answers
Sounds more like the carb sucked up something if u take it off and tear it down let soak in solvent than blow air thru body to dry and clear passages dont mess with adj
Posted on Sep 24, 2009
My lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Apr 18, 2012 | Craftsman Garden
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a craftsman gt 5000 with a briggs 22 hp ohv els725 engine. the engine starts hard, then seems to act like its going to die, then i can partially choke it and it seems fine. then when its put under...
indicates that there is a blockage in the main jet
or a restriction to the fuel flow
or a low float setting
the run on effect ( dieseling) is from hot spots in the cylinders igniting the mixture that is coming in through the idle circuit when the throttle is closed and the ignition turned off
you can have the valve clearances checked ( .010"hot inlet and .012" exhaust hot ) but as it runs ok- no missing or backfiring etc- it will not be a valve problem
Jun 25, 2017 | Garden
Craftsman Mower - 625 Briggs and Stratton Engine. The mower starts after I prime it 3 times. Starts up and runs at only half speed. I have taken the whole thing apart, changed the gas, cleaned the carb,...
Check the governer, its a lever that pulls the throttle plate from the engine side. Try manually overriding it (twist it open as the engine's running) and see if that does it.
May 09, 2011 | Craftsman 675 Torque 190cc 21" Briggs ...
Instructions for fixing the choke on a Craftsman LT-1000 lawn tra
I have been hearing alot of this problem. Well it is gravity flow. I just bought a 2002 lt1000 17 hp without a carb the guy was having the same problem so he sent the carb away to get checked out and low and behold it got lost. He waited the summer to see if it would show up but it did not. He got mad and bought a new bigger one. Any ways i am waiting on a new one. Now in my reading these problems i discovered that the fuel line coming out of the tank to the carb is lower. Might be somthing to look at. JIM
May 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs and Stratton 20 hp intek runs great idles great but after running for 15 min. it acts like is running out of fuel and dies. it starts back up if you wait a few min.fuel filter new , plugs new air...
Had the same problem with an almost new Craftsman w/ Intek 20.0 HP. Check all the "usual suspects" and had to have a tech come out. He had me start it. It ran for a few minutes and stopped (per usual). He immediately went to the Anti-Backfire solenoid. It is an electrically operated "plunger-style" fuel line blocker. They are famous for going bad. The part is about $65 and its sole purpose is to starve the engine of its fuel supply at shutdown so it won't backfire. If it is disabled, the user must throttle the engine down for 10 seconds or so before turning the key off in order to avoid backfires. Gee... let's see, 10 seconds of my time each time I use the mower vs $65 part ... No contest! Remove the solenoid, take a pair of electrician side cutters and snip off the tip of the plunger and reinstall it. Problem solved ! ! !
May 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
511 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
