Question about E-Machines eMachines Desktop PC
T6532 Startup Problem
I currently own an Emcahines T6532. When I turn it on, I can hear the fans starting and all of the LED's flash, on both the cpu and on my keyboard. The problem is, nothing comes on screen. It sounds like everything is astarting up okay, but nothing comes on screen. I have checked the video cables and all connections within the CPU, and I still cannot figure out the problem.
  • Doogle24 Dec 16, 2007
    Well see that's the problem. I cannot get windows to even boot up. The screen is black. I just rechecked all the connections within my computer, and nothing is loose or connected wrong.
  • Anonymous Dec 07, 2008
    solution #2
How do you install a new video card into the machine when you can't see any info on the monitor?? I'm having this problem now, I have the new video card installed in the PCI-Express slot and still....nothing. Is it plug and play and I should just wait or am I screwed?
Posted on Dec 21, 2007
  • 2,351 Answers
Lets make sure it's not the monitor. Connect it to another PC. Your video is a on board (intergrated) NVIDIA-GeForce-600. It can use up too 128Mb of shared memory. Shared from your system memory. If you have no display showing on a good monitor than your video card is not running correctly. In your case you do have a free (opened), PCI-Ex16 slot on the Mainboard. Try adding any PCI-E video card to your PC. If you get display, your intergrated video is defective. If you cannot find a decent PEG = PCI-E video card you can pick one up for as little as $30.00.
Your system:
PEG video card:
Posted on Dec 16, 2007
  • 383 Answers
Getting into Windows Safe Mode Start Windows Normally Reboot Return to OS Choices Menu
Good Luck, Should get ya back up and started .
Please dont for get to Vote.Thank You.
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
Pc not booting
If you hear the CPU fan turn on that doesn't mean the CPU itself is working. It can be only that the motherboard is getting power. Check all your connections such as monitor and peripherals and re-connect them. If you still don't get P.O.S.T. or ANY letters or boot options on your screen then your CPU is dead. (unless your monitor is bad)
Another easy diagnostic is using your ears. For example the pitch sound of the fan in some motherboards tends to lower and then increase because it's reading of the hard drive. This means your CPU is ok but either your graphics connection is bad or your monitor is.
Apr 22, 2012 | Intel Motherboard
My gateway computer do not turn on.the fan try to start and stop.what should be happenning?
I think that the CPU fan isn't working as it should and the CPU is overheating quickly. If the CPU is heating too fast, the mainboard is automaticly shutting down the all PC to prevent damage. Your thermal paste might be gone. Isn't the computer giving any sounds or LED flashes ?
Nov 02, 2010 | Gateway 830GM power supply **FREE **...
My computer will not start. When I plug the
there is a lot of factor for a death pc. ignore it all. just check the following :
1. is the hdd led flashing
2. remove the cpu cab and make sure that the fans are spining for both smps and processor
3. any un usual beeps at startup
4. any onscreen message or a blank screen
5. and bla bla ... ...
so far, let's fix it
1. check power and signal connectors of hdd or replace new .
2. re connect all the power connectors on the mobo or change a new smps
3. de assemble, clean and re assemble all the parts inside if there is any unusual beeps
good luck
Oct 16, 2009 | HP 435768-001 - Compaq Presario C300...
My Acer Aspire T180 won't boot
There is one thing you can try first before replacing *********** board.
Try shorting the jumpers on the CMOS battery. look for the JP3 jumper usually it is near the battery it looks like a quarter coin only a little bit smaller. If your having difficulty finding the jumper remove the battery for 24hrs. this will reset the CMOS then put it back in and power on the CPU.
If that doesn't work then replace *********** board is easy. bring it to a computer shop so they can match the devices in your CPU to match a motherboard of your choice.
Aug 04, 2009 | Computers & Internet
My computer wont go to windows xp when started up and it doesnt even go to any type start up screen
hi gllwymiller;
1.check all your connections
2.check monitor and cpu power
3.when you power on your cpu, do you actually hear the fan turning or see your power led light up?
4. what OS are you using?
5. Feel the rear fan or your CPU, is it blowing out air?
get back to me :)
Jul 01, 2008 | Gateway Computers & Internet
Emachines wont boot
Bad capacitor(s) on the motherboard can cause this problem, corrupted BIOS maybe... try flashing BIOS.
Probably the CPU if your not getting any error code beeps on startup.. NO Processor for the BIOS instructions thus no Beeps !
Nov 27, 2007 | E-Machines eMachines Desktop PC
No working
Virus infected or some startup programs make conflict with another program
go start run msconfig and startup
Desable all programs just DO NOT desable antivirus and let me know if u got help
Nov 02, 2007 | Acer TravelMate 290 Notebook
E-Machines eMachines Desktop PC Logo
364 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
