Question about Compaq Presario 5000 PC Desktop
Compaq presario 5000 desktop won't boot!
I have a compaq presario 5000 desktop that is about 7 years old. I restarted and the screen went blank. I came back to it and the power button was blinking. I turned it off, then back on again and it takes me to the compaq screen with two f button options. (f10-setup) or (f12-network service boot) after about 30 seconds the screen goes blank again. if i hit f10 it takes me to the setup options but if i hit f12 the screen goes blank again. Any ideas?
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Posted on Sep 24, 2009
  • 69 Answers
Oh that means you have a power failure so you have to take it for a repair
My compaq presario 500 wont boot up?compaq screen comes on then, blank screen,a little cursor in the upper lefthand side
virus is the cause. You are going to have to put in your windows cd and boot from it. Then do a "repair" and hopefully recovery your system if not you are going to have to do a total system wipe.
Sep 02, 2014 | Compaq Presario 5000 PC Desktop
My PC won't start? every time i start it the fan just spins fast and loud and nothing happens, the screen doesn't show. this happened when i took the PC apart. it a Compaq presario sr1610nx
Initially test the monitor in another pc, if display available use the monitor in Compaq presario sr1610nx. Load to BIOS by restarting and tapping F1, if the display available, the computer is ok. restart and tap F8, if the advanced boot option screen comes up, the software is ok.
Restart the computer and tap F10 and proceed with a destructive recovery to reload the operating system on the computer
May 07, 2010 | Compaq Presario 5000 PC Desktop
My compaq presario 5000 does not see the new memory and when i put in both 256 cards it won't boot up just a black screen
this might be incompatibility issue with the memory and pc. check for system specs from compaq and check also for maximum memory capacity.
Mar 29, 2010 | Compaq Presario 5000 PC Desktop
I hve a compaq presario 5000 desktop. It will
if you can view your desktop and use the menus, go to start/all programs/accessories/system tools/system restore, if you had enabled this option earlier then you can restore the system to an earlier known date when you system worked.
else you can try installing winXP again, try the option to "Update" when the install option comes on.
else start PC, before the WinXp screen comes on press F8 key, use the Safe Mode to start PC, if you can see everything then shut down and restart in normal mode.
Dec 06, 2009 | Compaq Presario 5000 PC Desktop
PC DO NOT BOOT
It seems that you don't have any Operating System installed. You need some bootable OS setup disk, and change BIOS settings to boot you PC from CD. Insert disk and restart PC, then follow onscreen instructions to setup OS.
Jan 27, 2009 | Compaq Presario 5000 PC Desktop
Stuck on safe mode
goto start --> run --> type msconfig --> there should be a option to change to the boot tab, under boot options tick safe mode off. and press apply and then ok and restart your computer
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 won't boot.
Be sure you do not have any Diskette in the A: or B: drive.
Jan 05, 2009 | Compaq Presario 5000 PC Desktop
RAM upgrade gone wrong?
Did you already try using last know good configuration?
When your computer boots instead of f10 press F8. Then select last known good configuration and enter.
if it didn't work try booting up the computer without the memory see if it will have the same problem.
May 12, 2008 | Compaq Presario 5000 PC Desktop
Unable to get past the blue screen
boot on safe mode and remove the program you have recently installed
Apr 08, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
399 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
