Need to know the wiring diagram for the contrator/relay
    President:
  • 1,922 Answers
Your two hot wires for 240 volt operation go to the two gold screws on the contactor,then the control voltage (24vac) goes on the side terminals of contactor
Posted on Sep 27, 2009
What does the starter relay fuse for a 1998 Isuzu rodeo look like and where is is located in the fuse box
Crystal, this is what I found on the Rodeo starter fuse/relay.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
99 Isuzu Rodeo LS Underhood Fuse Box Diagram Circuit Wiring Diagrams
1997 Isuzu Rodeo Question Fuse Box Diagram Electrical Problem
1999 Isuzu Rodeo Main Fuse Box Diagram Circuit Wiring Diagrams
1998 Trooper Relay Solenoid Starter 1998 Isuzu Trooper All of
Jul 06, 2016 | Isuzu Cars & Trucks
I would like to know where the main relay is in the 1989 ford ranger
Didn't see main relay, did see, eec power relay.
Hopefully, it is under hood, driver side, wheel well lining in relay pack. If several relays and you don't know which one, look at the wiring diagram for eec power relay, Match the wire colors with relay. If you can't read it, bbbind.com has free wiring diagrams, so does autozone.com.
Apr 17, 2016 | Ford Cars & Trucks
2005 starter wiring diagrams from ignition switch to starter soliniod
The ignition switch does not go to the starter solenoid . Pin 87 at the starter relay sends B+ voltage to the starter relay . Do you know what a starter relay is an how it works ? The ignition switch is an input to the PCM - engine computer . When the PCM sees this B+ voltage from the switch it energizes the starter relay sending B+ voltage to the starter solenoid . http://www.bbbind.com/free_tsb.html free wiring diagrams !
Mar 29, 2016 | 2005 Ford Freestar
Why would just my low beams not work on 03 galant.
It could be the low beam relay is bad , or the dimmer switch . You would need to know how to test the circuit . First off you need a wiring diagram of the circuit an a component location diagram ( in case you don't know where the relays are etc... Do you know how to use a test light an a DVOM - digital volt ohm meter . Do you know how to read a wiring diagram ? You could go to you tube an watch some videos on basic electrical trouble shooting . No Low Beam Head Lamp Chrysler Pacifica I know this isn't the same as yours ,doesn't matter . If you can fix one you can fix another ,with right wiring diagrams .
Dec 22, 2015 | Cars & Trucks
The top cover to relays on a f150truck is gone i need to know what relsy goes to what looking for the windshield wiper relay.please
What year F150 ? Go to www.bbbind.com free wiring diagrams , tsb's , fuse / relay box picture (diagram) . Click on technical information . Next page click on
Technical Service Bulletins & Wiring Diagrams
All TSB's and diagrams for every make and model - FREE
next page go to bottom an click I agree . next page click wiring diagrams. Then add your vehicle info , year ,make , model ,engine , then under system click on electrical distribution . then subsystem click fuse panel .
next
Nov 01, 2015 | Cars & Trucks
Wire diagram for the a/c cooling fan.. 1991 Jeep Commache
I am sorry but fixya doesn't have any wiring diagrams. They are copyrighted and not free to share.
Jul 22, 2012 | Jeep Comanche Cars & Trucks
I need diagrams for the fuse boxes in the dash and engine compartment so I can find the fuse/relay I need to replace. My dash lights, tail lights and windsheild wipers are out.
Hi
There are a couple of wiring diagram and manual available on the net. The relay you are talking about is the park lamp relay which supplies power to the tail lamps, license plate lights and both front and rear park lamps. If the park and plate lights are working the light switch, relay and supply power are good. You need to verify for a broken brown wire to the tail lamps (assuming the sockets, lamps and grounds on both tail lights are good) .If none of the lamps are working then the 15A fuse number 3, the light switch or the park lamp relay could be bad (note different contact in the main light switch work the other lights)
You can find a wiring diagram and component location at
www.autozone.com and http://www.pdfgeni.com/book/1998-ford-ranger-wiring-diagram-pdf.html
Let us know if you want something more else accept the solution.
Thanks for contacting fixya.com
May 23, 2010 | 1999 Ford Ranger SuperCab
Automotive wiring diagrams
Here's a freebie: go to 'autozone.com enter your car info (year, make, model, engine) click on repair manual, then chassis electrical, then to the far right of screen and down, wiring diagrams. Let me know if u have an trouble locating it.
Oct 27, 2008 | 1990 Buick Century
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
