Purchased a audiovox mp3 digital player model# CE531MP. the radio and clock programed and plays beautifully. when I insert a mp3 cd disk according to instructions, it does not read it. the display reads this way: CD READ. it stays this way period. I tried it with the remote controls, same result. followed the troubleshoot instructions, same result.
  • melodyjay Sep 24, 2009
    I am checking it out with a commercially prepare mp3 recording. I play it regulary on a portable mp3 player.
  • 496 Answers
Make sure the mp3 cd you burned is just that, meaning when you burn it, burn it as a data cd and make sure that all the files you put on it are .mp3 and not something like .mp4 .acc .wma if they are you'll have to get a conversion program and convert them into .mp3 files
Posted on Sep 24, 2009
CD player doesn't work on Timex Indiglo Radio Sounds CD player. No manual available. Can't use.
I never have seen this model but guess it's similar to any other CD-Radio model. You can download a manual from here
https://timexaudio.com/media/uploads/product/files/T618_IB59176_84.pdf
It should have a switch to select CD player.
Once you select CD player, open CD lid, insert a CD and play
If won't play, CD player is defective and if you don't know how to repair it you should take it to a repair service and evaluate if it's worth to reapir.
Aug 07, 2015 | Timex Audio Players & Recorders
What dsks does the CD player play. Does it play MP3 disks?
mp3 is actually a file format that made larger audio files take up less data space. If you have mp3 audio files on a compact disc(CD) it may play it if the player is designed to recognize the format. This was a much bigger issue years ago. Only way to tell is check the manufacturers specifications or simply try it. Good luck.
Apr 25, 2014 | Thomson RK300CDU CD/MP3/Radio/Cassette...
Can you play a mp3 on this radio and if so how
According to the specs it can play MP2 and MP2 music files,
You can check the specs from this WEB site.
http://shop.panasonic.com/shop/model/SC-HC27?t=specs
You need to copy the MP3 music files to an USB memory stick and connect it to the Panasonic then select the USB memory stick music file to play.
May 12, 2013 | Panasonic Sc-Hc27 - Micro System - Radio /...
CD player can't play recorded audio cd's
That sounds right, some of your cd players will not be able to play recorded cd's . It's lame, but that's the way it is. Sorry.
Jun 17, 2009 | Audio Players & Recorders
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
ISymphony CRDCD clock radio alarm programming
Play around with the Alarm1 button, test it every minute and when it goes off press Alarm1 again to stop it, not snooze. Then try pressing vol + as nothing is playing. Keep trying until your alarm goes off at the desired volume that you put in your Alarm1 settings
Mar 07, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
Coby mp3 player help
You have to convert the files. On the cd purchased with the player comes a conversion program.
Dec 26, 2008 | Coby MP-C7085 MP3 Player
I have an ONN MD880 MP3 player. None of the .wma songs that i am copying over are playing. The display shows they exist but it just won't play them. It did play one .MP3 track though. How can I get it to...
Good morning dear sir,
my mp3 player files are cruppted so that,s why i needed solution of of this problem (my produtec model no is md880/512) so kindly plz send me solution of this produtec problem and also send his softwrae or a formatting sotware.
kindly plz send it,
i am very thanks full to you.
Mar 26, 2008 | Audio Players & Recorders
Will not play cd
just received by durabrand under the counter cd/radio plugged it in and all i get is static on both what can i do to fix it
Jan 24, 2008 | Durabrand W375-K Clock Radio
AUDIOVOX CDA 100 AM/FM/CD setting clock
SETTING THE CLOCK - AUDIOVOX CDA-100
  1. Turn the vehicle ignition and radio "on".
  2. Press and hold the Time/Frequency Selector button approximately 2 seconds until the time display begins flashing on the display panel.
  3. Within 5 seconds after the time display begins flashing press the Manual Down Turning button (<<) to adjust the hours and the Manual Up Turning button (>>) to adjust the minutes to the correct time.
  4. Five seconds after the last hour or minute adjustment is made, the time will be set in the unit and normal operation can resume.
Contact Audiovox.com or 1-800-688-3135 and they will email (PDA) or fax a copy of the manual.
Oct 17, 2007 | Audiovox AM/FM/DVD/CD/MP3/WMA Receiver...
 Grubhead
Grubhead
