Question about Panasonic CT-32SL14 32" TV
Television has no power
We shut our television off to clean the screen and went to turn it on again and it will not turn on. there's no power going to it. the electric socket works fine. we plugged other things into it. the red light for power is not on.
  • 3 more comments
  • Anonymous Dec 18, 2007
    same problem no power no red lights and outlet is good
  • scc3872 Jan 22, 2008
    I am having the EXACT same problem!!! Is this t.v. just dead?
  • martinh212 Apr 06, 2008
    my tv is only two ears old, I take realy good care of it. Here is the problem
    Model Number CT-2SL14 TAU it does not want to turn on, I tried everything
  • walleye9064 Jun 18, 2008
    I have the same type of Panasonic television and also have the same problem. It is only 4 years old, and one day it just wouldn't tun on. I would like to be able to take off the back panal surrounding the power cord to see if there is a fuse I can replace, but the the tiny hex nuts require an obscure tool I have not been able to find anywhere.
    Anyone know where to find this tool?
  • maumes518 Dec 07, 2008
    I have a 27'' flat screen t.v. that doesnt turn on,not old,and the outlet works fine
I have a 27'' flat screen t.v. that doesnt turn on.
Posted on Dec 07, 2008
    Problem Solver:
Check the fuse. The person i got mine from said it was dead. i took it home opened the back and the fuse is very obvious replaced it with a slo-blo fuse and its back to normal!
Posted on Jan 30, 2008
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Why tv shuts off by itself?
Dear User,
People who have faced such problems have tried sticking th epower plug (Going into the TV) a little harder and the thing never went off again.
If this is not the case, then it could be the cat5 network cable. Try keeping it out and observe.
Let us know further
Nov 13, 2014 | Televison & Video
The picture was very dim and I removed the back panel and cleaned the lenses. Next, i slightly increased the the red color pot, there was a click and all three guns went out. Now there is no picture.
You should not adjust those knobs...Turn them back down - the ones marked "screen"...then power up and turn them up again slowly...if you go too far they will shut off again.
Once you get the tubes back on again as normal you can fix the original issue for dull video.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can get the correct parts, step by step photo instruction guides, and support from or click here
May 07, 2011 | Philips 60P8341 60" Rear Projection...
TV turns on with a green screen with curved horizontal lines.
It seems you may have a serious problem with your video board. That's why you are getting those symptoms. It's better if you replace it asap!
Aug 04, 2009 | Mitsubishi WS-48315 48" Rear Projection...
No power Mitsubishi Big Screen
Sounds like the power supply went bad. Repeated on/off pushing of the buttons causes the set to go into shut down. If a part is marginal this is when it'll go bad. Usually a bad power supply part and will need professional repair. Please rate!
Mar 26, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to
Dec 06, 2008 | Digimate DGL26 Television
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Panasonic CT-32SL14 32" TV Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
