Question about Honda 3000 Watt Portable Generator
I have a honda em3500 watt generator that runs good it does not make any electric. Can anyone help????????
  • 615 Answers
It could be the connectors need to be changed, when you open the front of the gen you will see a shaft with wires attached to it in both sides a small charcoal like peaces attached with a small wires each these connectors see if the are touching the shaft or not and how long they are if they not or too short that mean you need to replace them and you can get them from any please by looking at the manual and get the number for them and do search on the net or local store...However did you first reset all your brakes? let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
Why can't i run my a/c with honda 3000is generator
This generator will run an a/c unit up to 13500 btus and is good for 2800 watts. This is a small generator, the nameplate rating numbers need to jive before overloading the energy supply.
Jun 03, 2017 | Honda Electrical Supplies
How to find portable generator brands?
There are numerous sites online that are providing specifics of portable generator. These are typically specially manufactured for those people who are looking for good quality portable electrical generator and it's assessment. To find out more please click here.
Best Selling 2000 Watt Portable Generator Brands 2016 Top Brands Guide
Aug 05, 2016 | Electrical Supplies
I HAVE A GENERATOR HONDA E2500.
the generator is not big enough to run what you want
it needs to be 3500w minimum or 4.5w to be safe
although it is stated at 2500 watts , in fact that is the peak load on electric motor start up and its continuous rating will be around 1.8 watts
all of this is clearly stated on the specs plate on the generator
Dec 06, 2015 | Honda Generator E2500 Vintage Great...
How many watts does it need to run the airconditioner.Is a honda 3000 good enough
You can check the AC unit, it will tell you how much electricity it needs. Likely 15 or 20 amps. That's about 1500 or 2000 watts. What does your generator supply?
Jun 23, 2015 | Honda Electrical Supplies
I have an EM3500S
Make sure that the spark arrester screen on the exhaust isn't plugged with carbon. It takes just thirty seconds to pull it out. If it is clean, then the fuel filters are the next step. Hope that helps. Rod
Mar 21, 2014 | Honda 3000 Watt Portable Generator
Gas tank leaks is rusted inside and out am looking for a replacement tank
find a honda dealer and pray its not expensive... Or find a small engine shop and see if they have some junk generators laying around and buy the best tank they have and make it work...
Dec 27, 2013 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
Engine runs well no 12volts 110 or 220
The B&S unit uses an AGM battery. You can get one at Interstate. Use the 35 amp-hr size for this unit.
Oct 25, 2013 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
Can my eb5000 generator run an electric 7hp compressor
7 horsepower is approx 5150 Watts so the compressor would be taking this power while running. On startup however the compressor can take a surge of upto 3 or 4 times this power so the generator wouldn't be able to supply this demand . In any case it's not advisable to run a compressor off a generator unless the generator is high powered, 20KVA or greater for 7hp.
Mar 31, 2011 | Honda Mmd 5000 Watt Generator W/ Engine...
Honda eu3000is. runs but not putting out the full watts. Is this a cheap or expensive fix?
I have the 5kw Honda and have no problem, but I have never tried to run 5,000 watts either. It is reaching max rpms? Air filter clean? Good fuel? Oil? Have you run it much, or does it sit? How do you measure the wattage? Add up a bunch of things like, skil saw, pump, fridge, etc? Let's see, skill saw at 13 amps x 120 volts =1560 watts. Fridge probably idles at 7amps, starter windings use 10 or so amps, tv, 500 watts, computer, I would not run anything electronic with a genny, unless I had a spike protector on it. Check it out, hope this helps.
Mar 05, 2011 | Honda 3000 Watt Portable Generator
I have an em3500 honda generator which starts stalling out after 1/2 hour to an hour like it is running out of gas and then shuts off. I can restart it and it will run for 1/2 hour to hour and do the same...
Recheck for spark when it stalls. If you have lost spark I would say a heat damaged coil.
You should also drain and inspect the carb bowl. You may have low fuel flow which limits full throttle operation to 30 minutes or less. When it dies you are just refilling the bowl for the next run.
Good luck and be careful!
Aug 10, 2010 | Honda 3000 Watt Portable Generator
Honda 3000 Watt  Portable Generator Logo
1,443 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
