Question about Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW)
If the defroster unit is bad ,is it dangerous to let the freezer run? possibly a week?
  • 358 Answers
It's not dangerous ,you jusi have to defrosted manually by unplugged and let it defrost about once a week.
Posted on Sep 24, 2009
My upright frigidaire with ice and water dispenser gets really hot where the doors come together to close, what causes this?
Posted on Aug 20, 2010
We have Frigidaire Upright Freezer. After 6-7 days its stops cooling as its condenser gets ice around it whereas the fan is working good. We clean the ice and it again starts working/cooling.
There are a few possibilities. Freeze-ups are a result of the unit either not having sufficient airflow or the compressor running too long and too often. As you note the fan is good, chances are airflow is not the issue. There are a few quick items that you can check on:
1. Check door seals. Leaks will cause the interior to lose cooling faster and result in compressor overloading.
2. Do not overload the freezer. Too much inside the freezer will cause loss of airflow INSIDE the unit and can cause issues.
3. Avoid putting too much unfrozen material into the freezer at once. It takes a lot of work to remove all the heat from a large amount of material.
4. Avoid multiple opening and closing of the door. Upright freezers are inefficient as they lose all their cold air as soon as you open the door. Chest freezers do better if you must go into the unit often.
Lastly, undercharged refrigerant system can cause the same issue. If you don't have any of the other problems noted, have a serviceman check the refrigerant and fill the system as needed.
Feb 29, 2016 | Frigidaire Freezers
Freezer coil inside freezer box loads up rhyme ice preventing air flow. If I defrost the freezer it will work fine for a few weeks. I suspect there is a defrost timer, or humidity control that isn't...
There are three parts to all defrost systems.
1. Defrost Heater2. Defrost Timer3. Defrost Thermostat
Without a model number I could not look up a diagram or part numbers. I very seldom see a bad heating element. Most common is a bad defrost timer, second most common is the defrost thermostat.
Aug 02, 2011 | Sub-Zero Freezers
I have a Kenmore Refrigerator (bottom freezer) model 596.62822200. I replaced the overload relay last week but now the freezer is frosting up and restricting the air flow to the frig section. I have, I...
First of all, check the defrost element, you can do this by test lead, Active to one end and Neutral to the other end of the element leads, the element should get hot if its ok, if not, replace it, to check the timer, locate the clock advance dial, note its position by way of marker pen, allow the unit to run for 3-6 hrs and check position regulary of the dial, it should advance clockwise1/4 of a turn every 3 hrs, if that runs ok then its the thermo fuse.
Anymore help, contact me at wgheaven@yahoo.com.au
Regards Russ....ps dont forget to vote and goodluck.
May 07, 2011 | Kenmore Freezers
Hi i have a E5221 rt d fisher and paykel fridge freezer, freezer at top, the freezer always gets a build up of ice that collects on the slats and has a slightly swollen back wall witch seems to have ice...
try to clean the drain of your unit maybe it is clog up declog it to avoid drip. u said that ther is a build up of ice this means auto defrost not activate try to chek the defrost heater or defrost timer if have the unit this. or try to allign the door gasket possible theres a gap entry of outside air cause of build up of ice. bec it is came from moisture of air out side or avoid to much door opening.goodluck.
Feb 27, 2011 | Fisher Freezers
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
Maytag RSW2700 Freezer cold Refrigrator Warm
Check for excessive frost build up in the freezer on the back panel. This would indicate that you have a defrost problem. One of 3 things cause a ref not to defrost. Defrost timer may not be advancing to the defrost position on the timer...The defrost thermostat, located on the evaporator in the freezer, measures open (bad)...or you have a bad defrost heater. If you have an electronic defrost control,which is used on most Maytag, Jenair, or Amana units, this could be your problem. If you turn the unit off for 24 hours to let it defrost manually then it will last for about 2 weeks before freeze up again.
Apr 11, 2009 | Maytag Freezers
Frigidaire Freezer Model FFU20F9FW1 defrost problems
you say when you advance the defrost timer , id assume turn it ever so slightly the machine kicks on ad begins to freeze again?? then prior to advancing timer i would expect the unit to be totally dead(stuck in defrost mode).no fans,compressor or anything. that suonds like a bad timer or chck the wires going into the timer
Mar 05, 2008 | Freezers
Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Feb 03, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Traulsen freezer URS48DT
Turn cold control to Max. This keeps your compressor running for this troubleshooting exercise. Find and manually advance the defrost timer with a screwdriver or something similar. This will shut the compressor down and bring the defrost heater on. If this happens then you will know that your timer is bad.
If it is not that, the next thing to look at is the defrost heater itself or the thermal overload on your defrost heater. This keeps your defroster from overheating.
Jan 20, 2008 | Traulsen 7 cu. ft. / 198 liter Commercial...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 14.1 cu. ft. Upright Freezer (FFU14K0DW) Logo
182 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
