I have just had installed a new HICAPS machine on my business Machine that runs the Windows XP Professional OS. When I access mmy Front Desk software to access HICAPS, Front Desk does not detect the HICAPS machine. HICAPS is normally connected to COM1 however COM1 is not displayed on the Front Desk software. When I search for the port it says the HICAPS machine is not detected. Do I have to enable the USB port? How can I setup the COM1 port to detect the HICAPS machine? Currently, HICAPS are saying it is a software problem with Smartsoft and Smartsoft say it is a problem with the HICAPC connection. Do I have to configure a USB port to detect the HICAPS machine? I thought this was automatic on powering up the computer?
    President:
  • 1,865 Answers
Your com1 may already be used by another device. Normally USB ports are not used as com ports.
First, disable your serial and parallel ports in the BIOS. If that doesn't correct the problem, then go to device manager, expand the "Ports" devices and look for your HICAPS.
If HICAPS is listed there, then right click on it and select properties, then select port settings tab, then advanced, and you can see which Com port number was assigned near the bottom of the screen. You can use the drop down box to see if com1 is used.
If not used, then select com1, if it is used, you have to reassign whatever is using it to another com port
Posted on Sep 24, 2009
I purchased a business card maker softwarde CD The files are BCD. I have just upgraded to Windows 7 with my new computer and it is telling me that the software that I have been using isn"t...
Unfortunately many programs did not upgrade their software when windows 7 came out. However, there is something called XP mode in windows 7 which emulates an XP environment. You can install it by following these instructions: http://www.microsoft.com/windows/virtual-pc/download.aspx. With it you'll be able to do anything you could in XP including access these files in question.
May 11, 2011 | Computers & Internet
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
Unique customer Registration for MYOB Plus 11 I used MYOB 7 for years, and it worked all the way up to Windows 7 - now it won't even start. Its time to leave. I have a copy of MYOB Plus 11 that seems to...
Or, just get a version of windows 7 (look for "Windows Anytime Upgrade" on your computer) that can run a virtual XP machine (Pro or Ultimate versions), then download and install the virtual PC hyper-viser kernal and the XP Mode virtual machine.
Next, install your old copy of MYOB 7 into the XP mode virtual machine, copy your data files, and it should work....
EXPLANATION OF "WHY": MYOB 7 was actually meant to run on windows 95/98 machines, and this wasn't a problem in XP, because it could run a program that would basically emulate all of the win95/95 API's, under which MYOB 7 could run. Starting with windows vista, those old API's and emulation programs were basically tossed. Running the program under a virtual XP machine will give your old programs, like MYOB 7, access to those old API's. BTW, once the program is installed, it should auto register with windows 7. After which it will run in the win 7 interface almost as if it were a native program (will take longer to load as it has to load XP OS too).
One note, any custom forms (invoices, etc) may not work after copying them to the new installation of MYOB. Change their file attributes from Read Only (uncheck that box from within the files' properties dialog, via windows file explorer).
Oh, you'll definitely want as much RAM in your computer as you can get in there. XP mode will take a minimum of 512MB, but it'll be slow unless you set it up for at least a gig of ram.
Dec 11, 2010 | Myob Accounting Plus (BPJUBC00) for PC,...
Have a windows xp home edition,want to install windows xp professional pc wont let me install as 2nd OS,explain please
On the same machine, Windows does not tolerate second OS. Ont the other hand you can install any number of OS' if it is a Linux machine. The trick is to install Windows first and then install Linux etc. The Linux boot manager will tolerate Windows and others and incorporate then with itself. But vice versa is not possible.
May 07, 2010 | Microsoft Windows XP Professional
Can't install adobe reader 9.1 - Error 1402
Hai,
Error 1402 Could not open key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run.
Verify that you have sufficient access to that key, or
contact you support personnel.
They are using Windows XP Home edition. I fear that they
have one to many viruses/ spyware apps on the machine
already and it may just be time to re-install the OS, but
wanted to make sure this was not something that someone had
ran into before...
Thanks
Jaggu
Sep 19, 2009 | Adobe Computers & Internet
Cannot access anything on computer!!
Maybe the explorer is not loading automatically. As you start Task Manager from Ctrl+Alt+Del, go to new task and run explorer.exe.
OR If it still doesn't solve the problem try and repair the XP installation if you have the XP CD
Apr 19, 2009 | Microsoft Windows XP Professional SP3 Full...
Is software Compatible w MS Vista Windows?
You will
have to install and run it using Windows XP Compatability Mode
Jan 02, 2009 | Microsoft Office XP Professional OEM w/...
I INSTALLED MODEL T-S461-HSB TO MY WINDOWS XP AND IT STILL DON'T WRITE OR SHOW THE SIGNATURE THATS BEING WRITTEN DOWN. CAN YOU PLEASE TELL ME WHAT I'M DOING WRONG.
you download the software eapp for using the signature pads here is the minimum requirements of install eapp software
The eApp software was designed to function on both laptop and tablet PC computers.
Below are the hardware/software requirements for each configuration.
Note: eApp should run under Windows 2000, Windows XP Home and Media Center versions but Windows XP Professional (32 bit) and Windows Vista (32 bit) are the only 2 operating systems that the eApp help desk currently support. Use of an unsupported operating system can inhibit your ability to use eApp as it was intended and cause extra 3rd party support expenses.
Laptop -
Minimum Requirements:
1.2 GHz CPU or faster
512 MB Ram
20 GB Hard drive
Windows Vista
Recommended Requirements:
1.7 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash
Firewall and Virus protection software -
Any third-party protection software will do. Firewall and virus protection software should be running at all times to insure that your computer is not compromised and that customer information is not stolen. In the event of a system error you may be asked to provide the help desk with the results of a current virus scan to insure your machine is functioning properly. Failure to provide the scan results may result in a delay in resolving the problem.
Signature Capture Pad - Topaz SigLite Slim 1x5
Tablet PC -
512 MB Ram
20 GB Hard drive
Windows Vista
1.5 GHz CPU or faster
1 GB Ram
60 GB Hard drive
512MB USB Flash Drive
Tablet PC Signature Capture Software -
Topaz Tablet PC Software $100.00 USD
A signature capture pad is NOT required but special software is needed for the Tablet PC.
Mar 14, 2008 | Computers & Internet
43 people viewed this question
jasbo
jasbo
