Question about Motorola Mobility Rival A455 Cell Phone
The baclikght is set to on always and it wont turn on even when charging. i just got it. if i hold the phone up to the light i can see my wallpaper and stuff on the screen. what do i do
I NEED A WRITTEN MANUAL FOR SETTING UP MY CELL PHONE WITH STRAIGHT TALK
try: straighttalk.com for instructions or
call straight talk from another phone
Sep 28, 2016 | Cell Phones
LG KS360 phone - wallpaper always remains blank
make some of your phone memory free to make your phone work properly
Jan 29, 2010 | LG KS360 QWERTY Keyboard Phone BRAND...
How do i put wallpaper to screen size on the s5230
If you want to get a picture on the front of your phone do this:
Go to Menu--Settings--Display and Light--Wallpaper (If you have the picture in the wallpaper gallery then select it and click 'Set' and if you've got the picture in the different directory then go select 'images' and then go to the desired directory crop and click 'Set')
I would recommend this software Samsung Wallpaper Creator small in size but handy for creating wallpapers for your mobile where you can have 3 wallpapers in one and slide according to your choice on the phone.
Click on the link and go to the download Tab on the top and download the Zip file which is of 2.5 Mb aprox. Install on the PC and start creating wallpapers.You should use 240 * 400 size wallpaper aprox.each in the box.N you can always search for the pics on Google.
If there's more help you need let me know.
Good Luck.
Jan 18, 2010 | Samsung SGH-S5230 Cell Phone
EnV Touch Keeps resetting
I have VX11KV03 and I am having exactly the same issues; phone reseting to default display, sound, etc and trouble charging. Verizon tech support suggest a *211 call to update the software. Also, with the charging, even though this is still a hassel, unplug and replug in your phone after it says charge is complete. It will actually fill the charge the second time. Hopefully this wroks!
Oct 09, 2009 | LG enV VX9900 Cellular Phone
E baclikght is set to on always and it wont turn
The rival is a glitchy phone and is new so if you take it to a verizon store and they will replace it for FREE!!! It is a known problem with the software.
Sep 29, 2009 | Motorola Mobility Rival A455 Cell Phone
The backlight for my motorola Rival wont turn on
that is exactly what just happened to me today. i got it a week ago. and now i finally realized that if i hold it to a light i can see, but hardly. so i need help as well. happybagg129 did you figure out how ot fix this problem
Aug 02, 2009 | Cell Phones
A virus?
jonats,
question: have you tried charging your phone and does it indicates a display or light ups your LCD screen and indicates charging?
1) if it does charging and indicates "charging" on your LCD screen , try to do this:
note: make sure your battery does have a charge when doing this
a) remove the battery and install it again , but dont put the power on
b) press and hold this 3 buttons at the same time: "call " button / " * " button / "3" button
c) while holding and pressing the 3 buttons, switch and press the power button and wait till a display appear on the screen.
cheers.
mark
Jan 17, 2009 | Nokia 2610 Cellular Phone
Background keeps changing everytime i shake my cect i9 phonee
hey yes you can diable the shake feature on both the wallpaper and the music player
1. go to settings
2. hit phone setup
3.on the next menu go allll the way down to the bottom and you will see Gsensor swich wallpaper
and gesensor switch song. trust me its there u just gotta keep scrolling.
4. click off on them both and you have it.
hope this hepls, cuz hat shake is annoying
Dec 31, 2008 | Dual Electronics CECT P168 Cellular Phone
Nokia so annoying please need help
if u will remove ur memory card the problem will always rise u must simply copy ur wallpaper, ur ringtone, ur themes to phone memory and then remove memory card then set ur wallpaper, ur ringtone, ur theme. switch it of then insert memory card and then turn it on u will find that they are not reseted again. and please rate this solution. Have a good day
Apr 22, 2008 | Nokia 6288 Cellular Phone
Cant replace wallpaper
FOllow da steps
1>go 2 menu
2>themes
3>select whichever theme u want
4>go 2 options
5>edit
6>Select wallpaper as default
Jan 31, 2008 | Nokia 6630 Cellular Phone
Motorola Mobility Rival A455  Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
