Question about Asko T701 Electric Dryer
Belt issues The motor wheel came off which in turn threw the belt off. I have a panel off, but I'm not sure how the wheel connects with the motor. There seems like there should be a nut of some sort, but, if there is, it's M.I.A. Any help would be greatly appreciated. Thanks Steve
  • just2row Aug 12, 2008
    if the pin that connects the belt pulley to the motor is broken do i have to replace the motor?
  • 833 Answers
See if the wheel itself is undamaged. It should have a set screw in the hub. Match up the setscrew with an appropriate tool and then loosen it. Install the wheel back on the motor and tighten securely. Then, work the belt over the hub turning it to seat the belt. If the belt is damaged, replace it.
Posted on Dec 18, 2007
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
I have the belt connected to the wheel on my halo vacuum cleaner but it still will not turn
Is the motor shaft turning, if so be sure there is no hair buildup on the ends of the rollers and it is seated properly and you have good tension on the belt. If the motors not turning the motor shaft you need a new motor.
Feb 07, 2012 | Video Game Consoles & Games
Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW 1967 has broken. Is there a step by step guide on how to fit the replacement belt.
Very easy on all tumble dryers.
UNPLUG FROM POWER FIRST!
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Jun 23, 2011 | Dryers
I have a Kenmore Gas Dryer (model 11087471810) that threw its belt. I have the replacement belt and know how to replace that. When I opened the bottom of the dryer, I noticed the Idler pulley sitting at...
The idler pulley/tensioner fastens into two slots in the base of the dryer to the left of the motor . The belt goes around the drum then through the idler to the motor pulley ,you have to make a loop with the excess belt and feed it through the idler pulley, i normally pull the plastic pulley towards the right side of the dryer to give enough belt to go around the motor pulley then let the plastic pulley rest on the backside of the belt. do not turn the drum too much as you may pull the belt back off .
May 13, 2011 | Kenmore Dryers
Hot point washer drive belt has come off. However after removing the rear panel it appear the drive belt wheel nearest the floor has disapeared due to the shaft looking like it requires a pulley wheel for...
hello glen the belt has grooves on it the shaft at the bottom will have grooves it should just go back on make sure the motor not loose hope it helps
regards
shaun
Mar 06, 2011 | Washing Machines
CONVEYOR BELT NOT MOVING ON THE IMAGE TREADMILL
This could be because the belt on the motor that turns the belt you walk on is worn out. it has grooves on this belt that must be prominant to stay in the groves on the front roller and motor. The motor belt can be ordered for about 20$ shipped on ebay the motor belt number is 118016 this is a universal belt and fits this treadmil. Before buying the replacement belt check to see if this is for sure your problem. you can tell by opening the front of your treadmill and looking at the belt. You will see worn spots on the motor belt, or as I noticed when mine went bad, it will look like someone threw a bunch of rubber eracer shavings in your treadmill.
Aug 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
Drum problem
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Seat belt repair
first for the switch in window
the window switch is easy to test you just gotta remove switch out of the door leaving it hang there is a way to test with a guaged wire with fuse on it
take the main power wire and touch to the other connectors on the main switch if the window goes down or up the switch is the problem
im suggesting this way first with fuse cause its easier then testing the windows motor inside the door frame the switches should just pop out of the panel with out haveing to take panel off
now the seat belts there are 2 style that are common to chevy
one is inside the molding of the drivers panel you gotta pop off the panels easily and gently to get at the seat belt retractor this will be bolted to the metal under the molding
the other style is in the seat which you gotta unbolt the seat under the top half it will need to be unbolted at the bottom top half of seat
when you pull threw the top section of top half of seat remember to tie a string to the end so that when you pull threw top half the string will be there so you can connect too new belt and pull back threw with ease make the string long enough to hang
now the bottom half of seat what i call the "**** seat" you remove the molding at bottom around the belt retractor this will be bolted to floor bolt also pull belt threw molding once molding removed
disconnect any electric wires
now saftey issue involved with seat belt removal is for a reason i dont know of the dealer ship always discharges the belts and air bags once removed i guess because of static electricity becareful when you remove belt and replacing belts cause static elec. can set them off
once your seat belt is removed place in card board box and take to dealer after complition of installing new belt they will discharge your seat belt for you and then you can dispose of it properly
May 29, 2008 | 2000 Chevrolet Suburban
Hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Dec 29, 2007 | Hotpoint First Edition FEW12 Front Load...
Asko T701 Electric Dryer Logo
61 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Lollo Pop
Are you an Asko Dryer Expert? Answer questions, earn points and help others
