Question about Pioneer CDJ-700S Turntable
E-9109 pioneer dvjx1/has a new mecha and control pcb
Mercedes benz w211 code 9109
Mate I googled your question and a link to benzworld came up. If you read the 1st couple of answers you'll find your car has the wrong power steering fluid in it, This is the link-->
http://www.benzworld.org/forums/w211-e-class/1926537-correct-power-steering-fluid-09-e350.html
Hope I helped...
Mar 09, 2016 | Cars & Trucks
Tip
DVJ-X1 Cue before inserting disk.
The DVJ-X1 has a fun little bug/feature that is often over looked.
For a cd press the track forward/previous to select the track you want to play BEFORE you insert a disk, once you have the disk inserted and it initializes the deck will cue to that track automatically.
With a DVD you need to also select the TITLE as well as the TRACK most of the time with promo only or rock america disks there is only one track for videos so select TITLE 01 first then the appropriate Chapter.
on Jul 16, 2008 | Pioneer DVJX1 Turntable
How to fix mecha error on sony mhc-gx555
https://us.en.kb.sony.com/app/answers/detail/a_id/38877/~/the-stereo-system-malfunctions,-stops-responding,-or-displays-mecha-or
Jan 09, 2012 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Hi I'm getting a 8709 error code from my CDJ 800 any idea how to fix this?
According to Pioneer there are 2 possible faults associated with this error.
Option 1 - Error in mechanical operations Unrecoverable: Turn the power off. The error indication will be cleared. If the error still shows then it's Option 2.
Option 2 - Communication error between operating section and main section The error indication is cleared when the communication is finished (if it can finish).
Communication fault between the control interface (the PCB with all the switches on) and the main PCB (the motherboard in the base of the unit). It could be that the main ribbon cable that connects between the two has come loose or damaged. The control interface works on a digital PCM system, and if there is a problem with this, the motherboard throws a fit.
May 11, 2011 | Pioneer CDJ-800MK2 Turntable
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Mecha error o3
Mecha error 03 is a malfunction of the main pinch motor. Ninety-Five percent of the time the problem is that the motor has failed. The machine will more than likely have to be sent in for maintenance.
Nov 27, 2008 | Kodak 6800 Thermal Photo Printer
DVL-V888 has MECHA CPU message
DVD players are a dime a dozen, go get a new one....
Next time try to get a name brand such as a sony etc...
Aug 29, 2008 | Pioneer DVL-V888 DVD Player
Pioneer AVX-P7300DVD Flexible pcb
you can get the cable from pioneer for about 50 delivered same problem here
Dec 04, 2007 | Pioneer AVX-P7300DVD
Pioneer CDJ-700S Turntable Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
