Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Ignitors are sparking, but it appears gas not flowing.
Ignitors are sparking, but it appears gas does not flow from the tank. The tank is freshly filled. Why might gas not reach the ignitors?
    Scholar:
  • 138 Answers
There are a number of factors that can affect gas flow. #1. is the tank valve open? #2. check the POL spud [the thing that screws into the tank] for mud or anything that might plug the hole. #3. the regulator may be stuck, take a butter knife and tap the regulator with the handle lightly [that's the disc shaped thing that the POL is attached to]. #4. check the burner tube for restrictions such as a spider web or mud dauber nest
Posted on Sep 24, 2009
My rangemaster professional + 90 gas is when you turn on the oven and turn up the gas all the burners igniters start working can you please help .
Hello. Normally the ignitors WILL all start sparking--only the burner you've initiated will turn on. All the ignitors are wired together with a harness underneath the cooktop. This harness is connected to a spark module and when you choose whichever burner, it simply energizes the module. Only the burner with gas flowing will ignite. I hope this helps you!
Sep 03, 2015 | Rangemaster Kitchen Ranges
What does the flashing B mean on the hours display of a craftsman pro series lawn tractor mean
must have somthing in tank tack off clean it out real good chang fuel finter claen carb out blow lines out reinstall tank put fresh gas in not old gas check fuel pump when priming it thats about all you can do shoud be under warranty
Aug 23, 2014 | Garden
1995 kodiak no spark after 2 month storage
did you flush the gas lines and clean the tank, put some fresh gasoline in the tank like super unleaded
Nov 07, 2013 | Yamaha Motorcycles
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
21" Troy Built Self Propelled lawnmower engine won't start.
Remove spark plug, clean or replace. Remove air cleaner, clean or replace. Ensure oil is full. 30w. Drain old gas out of tank. Fill with fresh gas with Stabile added. Remove bowl from bottom of carb. clean. Observe bowl screw, see if hole goes thru screw. Clean out. Bread wrapper works nice. Observe float. Float down gas flow, float up no gas flow. Re-assemble, prime 3 times, pull rope 10 times to start. No start replace carb.
Jul 30, 2013 | Garden
2001 TW 200: i got the bike to start it ran for about 1 min the...
Make sure you've covered the basics: fuel petcock should be in the "on" position; ignition must be in "on" position; kill switch must be in the "run" position; bike should be in neutral. Make sure there's fresh gas in the tank. Check the oil through the sight glass on the right side of the engine, with the motorcycle balanced and level. Check the spark by taking out the plug and holding against the engine while you crank the starter. There should be a blue spark that appears with every second revolution of the engine. Check the gas flow by pulling the gas tube off the carb and turning on the petcock under the gas tank. Gas should flow freely from the tube. If all of these tests check out okay, you may have a carburetor problem, such as a plugged jet. This is quite common if the bike hasn't been used for some time. Removing the carb and cleaning it isn't overly daunting. Check the TW200 forum at http://tw200forum.com/. There's lots of info there. Also, download a copy of the shop manual. Good luck.
May 16, 2010 | 2001 Yamaha TW 200
Bike sat for year,has spark,cranks over,but wont start,bad gas maybe?
yes buddy drain tank put fresh fuel in and kick it over a few turns to allow fresh fuel to flow into engine get back to me if still no start
Oct 04, 2009 | 1995 Yamaha XV 535 Virago DX
No ignitors on gas range top
Pull out the bottom drawer and look for a cover over the spark ignition module. The ovens have glowbars and they have nothing to do with the top( different circuit).40a0b9a.jpg
Mar 11, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Honda 5.5 HP starts & dies
had the same problem with my Honda engined mower. you can't see it easily, but there is a very fine screen in the outlet of the fuel tank that gets blocked and fuel will not pass thru it fast enough to refill carb. remove tank and pour fuel in another container . Use a flexible plastic tube in the outlet or make a small wire hook to penetrate the screen,or preferably, remove it. confirm that fuel flows freely thru it, remove any debris, and reassemble. Change spark plug, add fresh fuel,and test. best of luck!!!! Ray
Dec 18, 2008 | Honda Chipper Blower and Vac: 5.5 Hp Gas
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
279 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
