Question about Simplicity for Children 4-in-1 Convertible 3045 Bassinet
Screws needed I have a crib I'm putting together and need to know what size of screw to use for the slide brackets.
  • 164 Answers
Http://www.simplicityforchildren.com/documents/Updated%20Model%20Numbers%208%20Sep%2008.pdf
check out this link just to be safe...
they r 11/2 in long
Posted on Sep 24, 2009
Have a bridgeport crib model# 48977 / MFg no. 580255 and I lost the screws and need to know what size screws are needed to put it together
Products America offers many different sets of instructions. We may be able to assist you with the instructions and the bolts/screws. You can email us at parts@productsamerica.com or call us at 800-205-9642.
Apr 18, 2012 | Baby Gear
Delta sienna 4844-4. I need the manual to convert from crib to toddler bed.
I have this same model and it was a hand me down but didn't come with any of the screws or any tools at all. Can some one please give me the specific sizes amounts and location to where i can purchase the screws and put the crib together?
Oct 22, 2011 | Delta Sienna Crib
I just picked up a crib on side of street . I am in financial debt that I cannt afford to buy a new crib the crib I picked up is model number 10-121 manufactured in 2003 . It has no bolts no screws nothing...
Most hardware stores will have the bolts you need. Take in the headboard and ask for help
getting a set of bolts that fit. Lowes and most others will have them too. One thing you may want to do
is call Cosco and gove them the model number and date of manufacture and ask if they can email
a set of instructions to assemble the bed. This way you make sure it is safely put together.
Cosco / Dorel Juvenile Group
Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609
Phone : (800) 544-1108
Apr 19, 2011 | Cosco Baby Gear
Need assembly manuel for Jenny Lind 012614 where can I find it online?? Every website takes me to another I am very frustrated....didn't think it would be such a ordeal to locate a manuel online???? Is...
Evenflo Jenny Lind Crib has been recalled.
When you call to get the kit to fix the problem (800) 356-2229 you could ask Evenflo directly!
Here are instructions without a manual...
1. Lay the headboard on the floor in front of you with the bracket holes and model number facing you. Use 2 ¾-inch wood screws to attach the L-bracket and the latch bracket to headboard. The L-bracket has 3 holes and attaches to the holes on the lowest section of the headboard. The latch bracket only has 2 holes and goes directly beneath the metal bracket for the mattress that is already attached. It should face toward the center of the headboard. Once you're done, complete the same procedure on the right side of the headboard. Then do the same for the footboard.
2. Stand the headboard up so you can attach the rails to it. First, place the cross dowel (the small piece of wood with a hole in the side of it) into the hole on the underside of the top rung of the rail. Then put a second dowel in the top side of the bottom rung. Line the left rail up with the headboard at a 90-degree angle, placing it in the brackets you just installed, and insert a 2 13/16-inch machine screw into each of the 2 holes on the front side of the headboard (the side that will face outward). Tighten each screw with your screwdriver until it hits the cross dowel. Then turn the cross dowel clockwise to lock it in. Do the same for the right side and then for the footboard.
3. Slide the mattress platform (the bottom of the crib) into the stabilizer rails (easy to distinguish, since they are the same size as the sides of the platform), putting the longer ones on the sides and the shorter ones on the ends. It will slide in easily. Use 5 ¾-inch screws to attach the hanger brackets to the corners of the platform. The holes are predrilled and you can only put the bracket on one way to match them up, so there is little worry that you will attach it wrong.
4. Put the support brackets (the straight, flat ones) on top of the predrilled holes in the underside of the stabilizer rails. Screw them in with ¾-inch wood screws. Then place the hanger brackets in the slots that were preinstalled on the headboard and footboard. Choose the level that will suit you best. Evenflo recommends the top two for infants.
5. Snap a caster (the round disc) on the bottom of each foot of the crib. Check that all your screws are tight to keep your baby safe.
Jan 29, 2011 | Evenflo Jenny Lind Crib
How to I take apart the drop down side of this crib. I had it installed and can't figure it out
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
Jan 04, 2011 | Cara Mia Louise Crib
Need instructionsSorelle Vicki 4-in-1 Convertible Crib - Espresso
IF YOU GO TO HERE http://www.sorellefurniture.com/parts.php
you can order the parts from the manufacturer, I had to do this because I was unable to find the right parts in a hardware store. I think it cost me around $20-$30 for all the parts plus I asked for directions and they sent them to.
hope that helps
Jul 17, 2010 | Sorelle Baby Gear
I need screws to put this crib together. Graco
Take one of the screws to homepot,and look at the threads on it!!You should be able to find something close to that screw!! If you don't have any screws than try to come slose to what it look like!!
May 15, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
I need to know the screw sizes (Ellis 4-in-1 convertible crib)
can you go to manufacturers website and get the assembly instructions?
Jan 24, 2009 | Simplicity for Children 4 in 1 Ellis Honey...
Jenny Lind Crib
model # 0161615 i need setup instructions
May 04, 2008 | Evenflo Jenny Lind Crib
Need screws to put baby bed back together (lost previous screws)
Simplicity for Children Ellis 4-in-1 Convertible Baby Crib
i lost all the screws and directions i need a new set does anyone know were i can any
Mar 24, 2008 | Evenflo Jenny Lind Crib
Simplicity for Children 4-in-1 Convertible 3045 Bassinet Logo
64 people viewed this question
Top Simplicity Baby Gear Experts
Scott Jelt
Scott Jelt
Greg Cann
Greg Cann
Jason Morris
Are you a Simplicity Baby Gear Expert? Answer questions, earn points and help others
