Question about Garmin iQue 3600 GPS Receiver
Iq3600a battery replaced for low battery message..even
Iq3600a battery replaced for low battery message..even after long charge..used various chargers..slight display flicker..battery indicater varies from full to medium to empty to full randomly
  • 3,051 Answers
Hello there
i would suggest first make sure you have the right charger for the device
next try removing the battery and inspect the terminals where the battery connects and clean with rubbing alcohol and a q-tip.
check to see if they are slightly bent or corroded or worn out.
next inspect the battery it'self to see if any of the terminals are corroded or bent and clean as nessassary .
replace battery if needed and have the batery tested ok?
i really hope this helps you solve your problem.
best regards michael
Posted on Sep 24, 2009
Message on my iPhone shows icon for iTunes to plug in a charger. What do I do?
Charge the phone at least overnite. Sometimes a replacement phone may arrive with a totally dead battery and the charger may not be able to put out enough current to operate the phone and charge it at the same time. If you want it to charge faster use a plug in charger with an output rating of 2 amps. They usually have 2 USB outputs and can charge two devices at the same time. If you only charge one device it's a piece of cake for the charger. .
Sep 10, 2014 | Apple iPhone 4S
Tip
Batteries & USB Devices & Charging
I see lots of people have trouble with their batteries for their various USB connected devices. Unfortunately you cannot usually charge a totally flat battery, or even a 1/2 charged one... from the USB port. These are only used to "Top Up" the battery... & keep it charged up via a "Trickle Charge". at very low current.If your battery is in this condition then you need to replace it with a fully charged one, and then use the USB to keep it fully charged.Another way is to connect the "Flat" battery up to a power supply or machine that charges them, at the right Voltage (Usually 3 - 6 V) & Current rating, and once fully charged, then use the USB.
on Jan 29, 2010 | Computers & Internet
Low Battery
Your battery may be losing it's ability to hold the charge or your charger may be fully replacing the charge in the battery. Personally, I suspect the battery.
Don
Jan 13, 2010 | Brady TLS2200 Thermal Label Printer
Battery backup is too low..
This may happens sometime with charger ,as i have the same problem and i replace the charger---i shown the mbile HTC authorised center
Aug 05, 2009 | HTC Touch P3450 Smartphone
Answering machine
I am not really sure what prompted the solution, however, while reading the
various questions asked by people someone must have mentioned a low battery
as a possility with their problem. And, after the checking the status, and
charging the battery, the message is recording as usual.
cillieb
Jan 09, 2009 | Panasonic KX-TG1033S Cordless Phone
Phone will not take charge
I have the same problem with my phone i really don't know what is going on~!!!
Sep 03, 2008 | RIM BlackBerry Pearl 8100
Low Battery display
no i have not but that is not a problem.
Feb 11, 2008 | Motorola Mobility PEBL U6 Cellular Phone
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Garmin iQue 3600 GPS Receiver Logo
121 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
