Question about GE GSS25LGM Side by Side Refrigerator
Continually having water in the reservoir and leaking what appears to be inside the freezer door. Removing the trim piece around the dispensor, water inside the slots that the trim piece attaches. when door opens and closes, water leaks out from the trim attachment holes.
    Sergeant:
    Champion:
  • 255 Answers
Find where line comes out under fridge in pan and blow back through line with shop air. clean evap pan inside freezer by defrosting and cleaning pan.
Posted on Sep 24, 2009
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Drinking water from refrigerator stopped dispensing immediately
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , pt # WR49X10173 which comes with instructions , to keep this from happening again .
May 29, 2010 | GE GSS20IEP Side by Side Refrigerator
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not working
OK, that should be no problem. Test your ice maker and fill with water if empty of ice. If full of ice and not moving to dump tell me. I need to help you locate the problem doing that and answering will tell me the problem. Also look around the door frame and inside for the model Profile that you have. and get back with me as soon as possible, Thanks Sea Breeze
Nov 19, 2009 | GE Profile Stainless Bottom-Freezer...
The ice shoot leaks water into the exterior tray
It sounds like the dispensor flap , is not closing , letting warm air into the freezer . Remove the top cover from the freezer door hinge and disconnect the plug . This removes power to the door . Use a small screwdriver , and pry the bottom of the dispensor display board outward . Remove the 3 plugs . Remove the 4 screws on the white dispensor housing ( 1 on each corner ) and slide the housing out . In the top right , inside the dispensor area , you will see a solenoid with a plunger . These 2 parts usually rust , and have to be replaced . Pt # WR62X10055 . Only 3 screws hold this piece on , so it can easily be replaced .
Sep 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Pure water dispensor leaks around the edge.
hi, this is a seal leak. its located behind the water release point. it could also be cracked, the assembly that is, but im sure its just a seal issue.
Feb 12, 2009 | Samsung RF265AA Bottom Freezer French Door...
Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Jan 01, 2009 | Viking 42 in Built In Professional...
''GE tfx28ppcb fridge has water puddle usually on right side
I had the same problem, I found that the plastic tubing feeding the water despendor and icemaker was run right along the comperssor, over tiem the from exposure to the heat the tubing had become brittle and cracked.  the black tube shiled had to slid up to expose the cracked tube. A  new tub installed and splice to existing dispensor feed line fixed probelm.
Dec 08, 2008 | Refrigerators
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
GE GSS25LGM Side by Side Refrigerator Logo
131 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
