Question about Dell Dimension E510 PC Desktop
The unit doesnt respond, and only certain lights come on the front
  • 748 Answers
Hello
Can you be more specific? Dell has installed in it's BIOS a set of beep codes. What sounds are you hearing? If no sound at all and only a couple of lights and no hard drive spin then I would say a power supply failure. Why don't you get back to me about the beep codes. www.micromendllc.com
Posted on Sep 24, 2009
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
My accelerator doesnt respond when i step on it. the speedometer too doesnt go beyond 40km/hr. help me
You must have the systems control module scanned for fault codes to begin the process of repairing this, this take special equipment and a trained technician.
Jun 13, 2012 | 2010 Nissan Rogue
Toshiba laptop keyboard doesnt respond to certain keys with correct letter. for example typing U gets a 3e?????
Hi
Go to the control panel and select the regional and language setting, Tab select Language and click the detail, you get new screen Text Service and Input Language hear you can select the Keyboard language (Default English United State) and change the keyboard setting. now your get perfect key before your have,
Good Luck
May 26, 2011 | Toshiba 310CDT Keyboard
The air conditioner doesnt respond to the remote
this units ahve a reset boton on the roght side of the unit open the lid like if you was gonna change filters a small boton should be on the right side of the unit push it and if your unit turns on then you need to get a new remote if it doesn't then is your PC board
Jun 02, 2010 | Continental Electric CE-AC7581 Ductless...
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
Washer has water in it wont drain or do anything see liights on console but doesnt respond
if this unit is a front loader you need to check at pump, more than likely there is a blockage at empeller
Mar 07, 2010 | Kenmore Elite 45986 Front Load Washer
Speedometer not working on 2002 Suzuki Volusia VL800. Need to fix soon any suggestions? Response greatly appreciated ASAP
Hi there!
I hope i responded quickly. The speedometer needle movement is caused by the speedometer cable that runts to your front wheel's gear unit. Check for the cable that goes near the axle of your front wheel and check that its properly screwed. Put the bike on stand and spin the wheel, if it still doesnt responed. Remove the cable, unscrew it near the front wheel axle first and try spinning the small "squared wire" inside, if you still can't get any action on the speedometer. Then chances are either your speedometer cable is cut in the middle or the speedometer display is jammed (unlikely). Remove the cable from the speedometer unit and check that it is freely rotating. Oil it and put back.
Next, we need to check for the gear near the axle of your front wheel. Screw the speedometer cable to the gear unit near the axle with the other end removed from the speedometer unit. Spin the wheel and check that the inner cable is responding or spinning.. If it doesnt, then your speedometer gears are worn out. Disassemble the front wheel and bring the gear assembly to the nearest parts dealer for purchase. Normally, they don't sell a repair kit so you'll need to purchase the whole gear assembly.
whichever the case, either you purchase a speedometer cable or the gear unit. Seldom will the speedometer unit be destroyed.
pardon me for not organizing this response as you were requesting a quick solution .. so i answered as quick as i could... hehe. Hope this helps!
Mar 16, 2009 | 2002 Suzuki VL 800 Volusia
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
2002 Toshiba 32" TV
I have the same problem with a 2005 Toshiba. Got a new remote...nothing. Seems like a lot of people are having this issue, must be a defect in the TV. Has anyone contacted Toshiba?
Nov 22, 2007 | Toshiba 32AF43 32" TV
Dell Dimension E510 PC Desktop Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
