Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Weedeater blower will not prime
When i push the bulb, i hear air wooshing in the tank. i recently replaced the fuel pickup line... it ran fine. does the other line force air into the gas tank to make the fuel go up the fuel line?? how does the prime work?
  • rlsid28 Sep 24, 2009
    it's not the item pictured. it's a blower ,like in my narrative.
    Welcome Back:
    Visited the website for 2 consecutive days.
The bulb is a two way valve. The inlet from the gas tank is shorter than the longer end, which goes to the carburator
Posted on Mar 02, 2010
Gas leaking everywhere. Yesterday it ran and today it is leaking gas when I prime it and try to start it. I have no idea where the gas is coming from on this ryobi weedeater. is this common?
Posted on Feb 27, 2010
  • 279 Answers
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Posted on Sep 24, 2009
Weedeater starts but won't run for more than 30 seconds
A lot of times the line that in the tank deteriorate so you mean may need to replace the line in the fuel tank
Aug 12, 2014 | Makita Em4251 24.5cc Gas Powered String...
Bulb primer replace
You need to make sure you have connected the fuel lines up correctly to the bulb, they pull fuel from the carb and push it back to the tank not the other way round
May 18, 2013 | Garden
Hi i have a named- weedeater, leafblower that the gas bulb and hose's rotten i got new bulb & line's but cant get it to run more than a min. the line coming out of the tube side top should it go to the...
The primer bulb's purpose is to PULL fresh fuel thru the fuel filter and gas line out of the tank into the carburetor, then to itself and then...PUSH any air/old fuel out to the fuel tank. If I am understanding what you say, you may be right. There are check valves in the primer bulb base that sometimes go bad and don't allow the proper flow. Check that fuel is being PULLED from the tank to the carb and that fuel/air is also being PUSHED back to the tank. Post back if need be. Sometimes (after a period of time) these carbs require a diaghram and/or rebuild kit.
Aug 12, 2010 | Garden
I need a fuel line schematic for a WeedEater brand Featherlite Plus weedeater
Presuming the primer bulb is on top of the carb....Fuel filter line out of gas tank goes to the lower part if carburetor body. The other line (normally larger in size) coming out of the fuel tank goes to the primer bulb outlet on the top of carb.
If the primer/purge bulb is not on the carb, things are a little different. The fuel filter line out of the tank still goes directly to the carb, as the bulb will pull old fuel/air out of the carb allowing fresh fuel to flow in and pushes old fuel/air back to the fuel tank.
Fresh fuel in, old fuel out of the carb...you can hook up a piece of fuel line to the bulb and tell which one is pulling and which one is pushing..or depress it with your fingers on it...either way you can tell.
Jul 04, 2010 | Garden
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
I re-tubed my trimmer and now the bulb won't prime
I had exactly the same problem. On my weedeater, there is a screen in the carb under the primer bulb that was dirty from the fuel line falling apart. After replacing the fuel line AND cleaning the screen, the primer bulb will move fuel and it runs great.
Jul 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Relacing fuel lines in a weedeater blower/vac
Sounds Correct on this End.
Jan 23, 2009 | Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,255 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
